I've installed an Rasperry Pi with a standard Rasbian image. Now I want to use my printer with cups (Samsung CLX-3185 - connected via USB). I've installed the drivers from the Samsung webpage and the pi noticed the printer. But I can't print anything:
stopped  "/usr/lib/cups/filter/rastertospl failed"
Log file:
 d [03/Aug/2014:19:50:11 +0000] cupsdFinishProcess(pid=11326, name=0xbee803e4, namelen=1024, job_id=0xbee803e0(4)) = "/usr/lib/cups/filter/rastertospl"
 D [03/Aug/2014:19:50:11 +0000] PID 11326 (/usr/lib/cups/filter/rastertospl) stopped with status 1.
 d [03/Aug/2014:19:50:11 +0000] select_timeout(-1): 30 seconds to write dirty config/state files
Is there a solution?
MasterCrumble
The rastertospl filter used for Samsung’s driver does appearently not work for armhf architectures (like Raspbian uses). However, you may have success with the splix-drivers:
sudo apt-get install printer-driver-splix
Splix also worked with the unlisted ML-1915 printer I had: http://openprinting.org/driver/splix/
I do have a Samsung ML2160 plugged into an old arm-based NAS for which I can't find a working driver as Anders Johansonn.
Instead I setup a Generic PostScript Printer on the NAS with CUPS and share it over the network. Thus I can print from local computers on the network given that the driver is installed on them.
The drawback is that I can't print directly from the NAS but this is fine for me.
antoine
  • 191
