NTPD appears to run successfully and poll the time server, however it doesn't actually set the time.
# ntpd -d &
ntp engine ready
reply from 83.170.75.28: offset 1348642593.061240 delay 0.035977, next query 9s
# date
Thu Jan 1 10:53:29 BST 1970
This is using the latest hf Arch Arm kernel.
Jivings
  • 22,656
  • 94
  • 140
Quoting from ntpd documentation:
In case there is no TOY chip or for some reason its time is more than 1000s from the server time, ntpd assumes something must be terribly wrong and the only reliable action is for the operator to intervene and set the clock by hand.
Again, quoting from the ntpd man page:
-s Set the time immediately at startup if the local clock is off by more than 180 seconds. Allows for a large time correction, eliminating the need to run rdate(8) before starting.
So a ntpd -s in a terminal should be sufficient to fix the problem and let ntpd adjust the time normally from there on.
UPDATE: now it should be ntpd -g
Avio
  • 1,239
