9
Running the latest debian distro (2012-09-18-wheezy) and latest firmware ? (rpi-update).
How to install and run a working Quake 3 game?
Kind regards
Christian
  • 1,230
  • 25
Change to the directory where you will store the downloaded files:
cd /home/pi/
Download the files using wget:
wget http://radium.hexxeh.net/quake3.zip
wget http://www.andershizzle.com/Q3%20Demo%20Paks.zip
Unzip the two files you just downloaded using unzip:
unzip quake3.zip
unzip Q3\ Demo\ Paks.zip
Move all of the pak files that were extracted from Q3 Demo Paks.zip over to quake3/baseq3/ using the mv command:
mv baseq3/pak* quake3/baseq3/
Change the file permissions using chmod:
chmod +x quake3/start.sh
chmod +x quake3/ioquake3.arm
chmod +x quake3/ioq3ded.arm
Change the current directory:
cd quake3
Then you can start it with the following command:
./start.sh
Reference: http://blog.modmypi.com/2012/06/1.html
Steve Robillard
  • 34,988
  • 106
  • 110
This works: I was logged on as root the whole time, so remove the sudo!
1.Make sure you're up-to-date:
sudo apt-get update
sudo apt-get dist-upgrade
sudo rpi-update 192Reboot.
2.Install required packages:
sudo apt-get install git gcc build-essential libsdl1.2-dev
3.Download the Quake 3 source code:
mkdir ~/src
cd ~/src
git clone https://github.com/raspberrypi/quake3.git
cd quake3
4. Edit build.sh in quake3 directory:
change line 8 to this:  ARM_LIBS=/opt/vc/lib
change line 16 to this: INCLUDES="-I/opt/vc/include -I/opt/vc/include/interface/vcos/pthreads"
comment out line 19:    #CROSS_COMPILE=bcm2708-
5. Do a ./build.sh
./build.sh
6. Wait for compilation to finish, takes about 1 hour on RasPi.
7. Find copies of the following somewhere (other guides will show you) and place in build/release-linux-arm/baseq3:
cd ..
sudo wget http://dl.dropbox.com/u/1816557/Q3%20Demo%20Paks.zip
sudo unzip Q3\ Demo\ Paks.zip
sudo rm Q3\ Demo\ Paks.zip
sudo mv ./baseq3/pak* ./quake3/build/release-linux-arm/baseq3/
sudo rm -rf ./baseq3/
.8. Run ioquake3.arm. Shoot things.
cd quake3
cd build
cd release-linux-arm
./ioquake3.arm
If your not logged in as root You might try this also before step 8 (I haven't)
7.2.Update your permissions for directFB access: sudo usermod -a -G video [your_username]Log out, log back in. This will allow you to run game as non-root. Works with other directFB/SDL based stuff, too.
Kind Regards Chris
Sources: http://www.raspbian.org/RaspbianQuake3 http://mitchtech.net/install-quake-3-on-raspberry-pi/
Christian
  • 1,230
  • 25
