There is a lot of discussion online about whether using Pifm is okay because it is low powered, or whether it is very bad because the square waves cause a lot of interference outside the FM band.
With something along the lines of a 30cm antenna, is that harmonic interference really noticeable? Similarly, regardless of how bad the interference is, have there been any cases of someone being contacted by the FCC or similar organization in response to complaints of interference?
andrewmh20
  • 139
Flying "under the radar" is nebulous at best. You are correct in that FCC is called in on interference. It normally does require a complaint (which I assure you that you don't want to deal with). However, with low power such as you intend, the chances of you interfering with an authorized broadcast are low. I was involved in a situation (years ago where a 100KW induction heater (10 kHz) had been reported as interfering in the AM broadcast band. The reduction in interference was approved by the FCC, problem solved. No penalties to the offending party. Perhaps go about your property, and those of the neighborhood and see if you can detect FM broadcast of your device. Being responsible party you have already indicated your interest. Make sure that no local emergency broadcasts by your neighbors (Home Alert necklace, etc are endangered). Go forth and sin no more
Marla
  • 394
There is no doubt that operation is illegal. Regulations vary around the world, but in most countries operating unlicensed radio transmitters is illegal. In many places it is OK to operate low power equipment which is approved under a class licence. WiFi and radio microphones fall into these categories. CB radio and model control are also legal, even though using higher power, but only in approved bands.
There is no way Pifm would qualify, because of the out of band emissions.
Having said this, the chances of being caught and prosecuted is low.
It is 100% illegal. The question is kind of like asking if it's illegal to drive without a liscence if you know how to drive really well. The answer is, it is illegal regardless of the liklihood that you will be caught and regardless of how apparent it is that you are breaking the law. If you don't get caught you won't get punished, but that doesn't make it legal.
I've ran PiFM for a month straight without any problems, but run it at your own risk. As you mentioned it is pretty low power, so if you're getting caught chances are you were interfering with some pretty important government transmissions (PiFM is really messy and can interfere with lots of frequencies).
Kovy Jacob
  • 148
