I'm having an operational error when trying to run IDLE program (Python) in Raspberry Pi and it prompt me an error sentences:
File "/var/www/Sensor-LED.py", line 34, in <module>
Blink (int(iterations), float(speed))
File "/var/www/Sensor-LED.py", line 15, in Blink
curs.execute("INSERT INTO led values(timestamp('now'), (?)")
OperationalError: no such function: timestamp
I use SQLite 3 in Raspberry Pi to create my table and I only created 1 column which is timestamp only.
import sqlite3
import RPi.GPIO as GPIO
import time
import datetime
GPIO.setmode(GPIO.BOARD) ## Use board pin numbering
GPIO.setup(7, GPIO.OUT) ## Setup GPIO Pin 7 to OUT
dbname='/var/www/ledDB.db'
##Define a function named Blink()
def Blink(numTimes, speed):
conn=sqlite3.connect(dbname)
curs=conn.cursor()
curs.execute("INSERT INTO led values(timestamp('now'), (?))")
for i in range(numTimes):## Run loop numTimes
print "Iteration " + str(i + 1)## Print current loop
GPIO.output(7, True)## Switch on pin 7
time.sleep(speed)## Wait
GPIO.output(7, False)## Switch off pin 7
#commit the changes
conn.commit()
conn.close()
print "Done" ## When loop is complete, print "Done"
GPIO.cleanup()
## Ask user for total number of blinks and length of each blink
iterations = raw_input("Enter total number of times to blink: ")
speed = raw_input("Enter length of each blink(seconds): ")
## Start Blink() function. Convert user input from strings to numeric data types and
##pass to Blink() as parameters
Blink(int(iterations), float(speed))
Hope you guys could help me out with it as soon as possible.
