37
I know this question may have been asked before. I just want to know if there are any alternatives to the Raspberry Pi. I want to use it as an XMBC station, but the reviews tell me that it's a bit buggy as of now. The video forwarding and the loading times are not very good.
What I get from all this is that a Raspberry Pi is a good machine for beginners to learn programming, but power users might want to look somewhere else.
Finally, here is my question: What are some other alternatives to the Raspberry Pi. They must be compatible with any flavor of linux. One I like is PandaBoard.
Any other suggestion like that would be great. Price range is between $0-240
Jacobm001
  • 11,904
  • 47
  • 58
tinyhook
  • 479
There are a lot of Embedded Linux boards/systems available, here is an overview.
(This list is by no means complete, anyone that is missing something please add it to the list to make it as complete as possible.)
x86 based
  1. VIA ARTiGO A1200
    CPU: 1.0GHz VIA Eden™ X2 processor,
    GPU: VIA Chrome 9
    RAM Memory: Up to 4GB of DDR3 1066 SODIMM RAM,
    NAND Flash: None,
    Storage: Built-in 2.5” SATA, Built-in CFast socket,
    I/O: HDMI, VGA, 4 USB 2.0, 2 GigaLAN, 2 COM, 1 CFast socket,
    Other Features: HD, MPEG-2, WMV9, VC1 & H.264 video decoding hardware acceleration,
    Site: http://www.viaembedded.com/en/products/minipcs/1850/1/ARTiGO_A1200.html
    Bare PCB: No
  2. VIA ARTiGO A1150
    CPU: 1.0GHz VIA dual core Eden™ X2 64-bit processor,
    GPU: VIA Chrome 9
    NAND Flash: None,
    Storage: 2.5” SATA, optional SD,
    I/O: HDMI, USB device port, 4 USB 2.0 ports, VGA, Gigabit LAN,
    Site: http://www.viaembedded.com/en/products/minipcs/1650/1/ARTiGO_A1150_(Pico-ITX).html
    Bare PCB: No
ARM based
  1. Rikomagic MK802
    CPU: 1.0GHz Cortex-A8
    SOC: Allwinner A10,
    GPU: MALI400MP OpenGL ES 2.0,
    RAM Memory: 1GB / 512MB DDR3
    NAND Flash: 4GB
    Storage: microSD
    I/O: HDMI, Wifi 802.11b/g, WAPI (Ralink8188), 2 (USB + mini USB OTG)
    Other Features:
    Site: http://store.cloudsto.com/rikomagic/rikomagic-mk802-detail.html
    Bare PCB: No
  2. Rikomagic MK802II
    SOC: Allwinner A10,
    NAND Flash: 4GB
    Storage: microSD
    I/O: HDMI, Wifi 802.11b/g, WAPI (Ralink8188), 2x Micro USB, 1x USB2.0,
    Other Features:
    Site: http://store.cloudsto.com/rikomagic/rikomagic-mk802-ii-detail.html
    Bare PCB: No
  3. Mele A1000
    CPU: 1GHz+ Cortex-A8,
    SOC: Allwinner A10,
    RAM Memory: 512MB DDR3
    NAND Flash: 4GB
    Storage: SD, SATA
    I/O: HDMI, CVBS, VGA, Audio R+L, optical SPDIF, Ethernet 10/100Mbps, Wifi 802.11b/g/n WAPI(Ralink8188), UART, USB
    Other Features:
    Site: ??
    Bare PCB: No
  4. Rhombus-Tech A10 EOMA-68
    CPU: 1.2ghz Cortex A8 ARM Core
    SOC: Allwinner A10
    RAM Memory: 1GB DDR3
    NAND Flash: 1Gb - 16Gb
    Storage: Micro-SD, SATA
    I/O: HDMI, TV-Out, GPIO, I2C, PWM, Keyboard Matrix (8x8), built-in Resistive Touchscreen Controller, 4 SDIO interfaces (SD 3.0, UHI class), USB 2.0 Host as well as a 2nd USB-OTG Interface, 10/100Mb Ethernet
    Other Features:
    Site: http://rhombus-tech.net/allwinner_a10/
    Bare PCB: No
  5. Gooseberry board
    CPU: 1.2ghz Cortex A8 ARM Core (up to 1.5Ghz)
    SOC: Allwinner A10
    RAM Memory: 512MB
    NAND Flash: 4GB
    Storage: Micro SD
    I/O: HDMI, 1x Mini Usb, Wifi, Audio 3.5mm Earphone Jack
    Other Features:
    Site: http://gooseberry.atspace.co.uk/
    Bare PCB: Yes
  6. A13-OLinuXino
    CPU: 1GHz A13 Cortex A8
    SOC: Allwinner A13
    RAM Memory: 512 MB
    NAND Flash: optional 4GB
    Storage: SD
    I/O: 3 + 1 USB Host, 3 available for users 1 for (optional) WIFI RTL8188CU 802.11n 150Mbit module on board, 1 USB OTG which can power the board, VGA video output, LCD signals available on connector so you still can use LCD if you disable VGA/HDMI, Audio Output,Microphone Input,RTC PCF8536 on board for real time clock and alarms,5 Keys on board for android navigation,UEXT connector for connecting addtional UEXT modules like Zigbee, Bluetooth, Relays,GPIO connector with 68/74 pins and these signals: 17 for adding NAND flash; 22 for connecting LCDs; 20+4 including 8 GPIOs which can be input, output, interrupt sources; 3x I2C; 2x UARTs; SDIO2 for connectinf SDcards and modules; 5 system pins: +5V, +3.3V, GND, RESET, NMI Optional low cost 7" LCD with touchscreen
    Other Features:
    Site: https://www.olimex.com/Products/OLinuXino/A13/A13-OLinuXino-WIFI-DEV/
    Bare PCB: Yes
  7. VIA APC 8750
    CPU: 800 MHz ARM11
    SOC: VIA WonderMedia 8750
    GPU: OpenGL ES 2.0
    RAM Memory: DDR3 512MB
    NAND Flash: 3GB
    Storage: microSD
    I/O: HDMI, VGA, USB 2.0 (x4), Audio out / Mic in, 10/100 Ethernet
    Other Features:
    Site: http://apc.io/
    Bare PCB: Yes
  8. BeagleBoard Rev. C4
    CPU: 720 MHz ARM Cortex-A8
    SOC: TI OMAP3530
    GPU: PowerVR SGX
    RAM Memory: 256 MB
    NAND Flash: 256 MB
    Storage: SD/MMC
    I/O: HDMI, S-Video, Stereo in and out jacks, 1 USB, USB OTGRS-232 port, JTAG, I2C, I2S, SPI, MMC/SD
    Other Features:
    Site: http://beagleboard.org/hardware/design
    Bare PCB: Yes
  9. BeagleBoard-xM
    CPU: 1 GHz Cortex-A8
    SOC: TI DM3730
    GPU: PowerVR SGX
    RAM Memory: 512 MB
    NAND Flash: 4 GB
    Storage: MicroSD
    I/O: HDMI, S-Video, Stereo in and out jacks, 4x USB, 10/100 Ethernet,RS-232 port, JTAG connector, Camera port, I2C, I2S, SPI, MMC/SD
    Other Features:
    Bare PCB: Yes
  10. BeagleBone
    CPU: (500MHZ-USB Powered, 720MHZ-DC Powered) Cortex A8
    SOC: TI AM3359 Sitara
    GPU: PowerVR SGX530
    RAM Memory: 256MB DDR2
    NAND Flash:
    Storage: microSD
    I/O: USB 2.0 Client Port, Host Port, JTAG, more through Expansion boards
    Other Features:
    Bare PCB: Yes
  11. PandaBoard
    CPU: 1GHz Dual-core ARM Cortex-A9 MPCore
    SOC: OMAP4430
    GPU: PowerVR SGX540
    RAM Memory: 1GB DDR2
    NAND Flash:
    Storage: SD/MMC
    I/O: HDMI, DVI-D, LCD, 10/100 Ethernet, 802.11 b/g/n (WiLink™ 6.0), Bluetooth v2.1 + EDR, General purpose (I2C, GPMC, USB, MMC, DSS, ETM), Camera, LCD, JTAG, UART/RS-232
    Other Features:
    Site: http://pandaboard.org/
    Bare PCB: Yes
  12. PandaBoard ES
    CPU: 1.2 GHz Dual-core ARM Cortex-A9 MPCore
    SOC: OMAP4460
    GPU: PowerVR SGX540
    NAND Flash:
    Storage: SD/MMC
    Other Features:
    Bare PCB: Yes
  13. Cotton Candy
    CPU: 1.2 GHz dual-core ARM Cortex-A9
    SOC: Samsung Exynos 4210
    RAM Memory: 1 GB
    NAND Flash:
    Storage: MicroSD SDXC
    I/O: HDMI with audio, Wifi 802.11 b/g/n, Bluetooth 2.1 + EDR
    Other Features:
    Site: http://www.fxitech.com/products/
    Bare PCB: No
  14. CuBox
    CPU: 800 MHz ARMv7
    SOC: Marvell Armada 510 (88AP510)
    GPU: Vivante GC600
    RAM Memory: 1 GB DDR3
    NAND Flash:
    Storage: MicroSD, 1 x eSATA
    I/O: HDMI, S/PDIF, 2 x USB, 1000baseT Ethernet, Infra-red receiver with LIRC support
    Other Features:
    Site: http://www.solid-run.com/products/cubox
    Bare PCB: No
  15. Hawkboard
    CPU: 300-MHz ARM926EJ
    SOC: TI OMAP-L138
    GPU: ??
    RAM Memory: 128 MByte
    NAND Flash: 128 MByte
    Storage: SATA
    I/O: VGA, Composite IN, USB 1.1 Host, USB 2.0 OTG, VPIF, UPP, PRU, LCDC, 2x UART, 2x SPI , 1x I2C , eCAP, eHRPWM, GPIO, JTAG
    Other Features:
    Site: http://www.hawkboard.org/
    Bare PCB: Yes
  16. IGEP v2
    CPU: ARM Cortex A8 1GHz
    SOC: Ti DM3730
    GPU: SGX530 @ 200 MHz
    RAM Memory: 512 MB
    NAND Flash: 512 MB
    Storage: MicroSD
    I/O: DVI-D, TFT Interface 24 bit, Stereo audio in / out, USB host + Mini OTG host/slave, 10/100 Mb BaseT, Wifi 802.11 b/g, Bluetooth BC4 - Class 2.0, 3 x UART, Expansion boards available, McBSP, McSPI, I2C, GPIO
    Other Features:
    Site: http://igep.es/products/processor-boards/igepv2-board
    Bare PCB: Yes
  17. IGEP COM Proton & Module
    CPU: 1GHZ ARM CORTEX A8 (720Mhz for OMAP3530)
    SOC: DM3730 (optional OMAP3530)
    GPU: SGX 530 (200Mhz), (110Mhz for OMAP3530)
    RAM Memory: 512 MB
    NAND Flash: 512 MB
    Storage: MicroSD
    I/O: 1 x USB 2.0 OTG, JTAG, Expansion: USB, DDS, Camera, uart, SPI, McBSP, I2C, keypad
    Other Features:
    Site Module: http://igep.es/products/processor-boards/igep-com-module
    Site Proton: http://igep.es/products/processor-boards/igep-com-proton
    Bare PCB: Yes
  18. Gumstix Overo series
    CPU: ARM Cortex-A8 Up to 1GHz
    SOC: AM3703, DM3730, OMAP3503, OMAP3530
    GPU: ??
    RAM Memory: 512MB or 256MB
    NAND Flash: 0 - 512MB
    Storage: microSD
    I/O: Many, by using various
    Other Features:
    Site: https://www.gumstix.com/store/index.php?cPath=33
    Bare PCB: Yes
  19. Origen Board
    CPU: 1.4GHz Dual Core Cortex-A9
    RAM Memory: 1GB (POP Type)
    NAND Flash:
    Storage: 2 x SD/MMC
    I/O: mini HDMI, LCD, SDcard, Serial, USB 2.0 Host x 2, USB 2.0 Device JTAG , Ethernet (10/100 Mbps), HDMI support, WiFi/Bluetooth Combo, RS232, JTAG, camera
    Other Features:
    Site: http://www.origenboard.org/wiki/index.php/Main_Page
    Bare PCB: Yes
  20. Nimbus
    CPU: ARM9E
    SOC: 1.2 GHz ARM Marvell Kirkwood 88F6281
    GPU: ??
    RAM Memory: 512MB DDR2
    NAND Flash: 512MB
    Storage:
    I/O: USB 2.0 Host, Gigabit Ethernet
    Other Features:
    Site: http://www.ionicsplug.com/nimbus.html
    Bare PCB: No
  21. Stratus
    CPU: ARM9E
    GPU: ??
    NAND Flash: 512MB
    Storage:
    I/O: USB 2.0 Host, Gigabit Ethernet, 802.11 b/g (Micro-AP / Client) WPS support on Client Mode, Bluetooth 2.1 + EDR, ZWave (US, EU), ZigBee (802.15.4)
    Other Features:
    Site: http://www.ionicsplug.com/stratus.html
    Bare PCB: No
  22. Cirrus
    CPU: ARM9E
    SOC: 2.0 GHz Processor Speed Marvell Armada 88F6282
    GPU: ??
    NAND Flash: 512MB
    Storage: SATA
    I/O: WLAN 802.11 b/g/n (configurable as client or uAP),WPS Support on Client Mode, Dual Gigabit Ethernet Ports at 10/100/1000 Base-T, USB 2.0 Host (Type A)
    Other Features:
    Site: http://www.ionicsplug.com/cirrus.html
    Bare PCB: No
  23. SheevaPlug dev kit (Basic)
    CPU: ARM9E
    SOC: 1.2Ghz Marvel Kirkwood 6281
    GPU: ??
    NAND Flash: 512 MB
    Storage: SDIO
    I/O: USB 2.0 Host, RTC w/ Battery
    Other Features:
    Site: http://www.globalscaletechnologies.com/t-sheevaplugdetails.aspx
    Bare PCB: No
  24. GuruPlug Server
    CPU: ARM9E
    GPU: ??
    NAND Flash: 512MB
    Storage: MicroSD
    I/O: 1 x Gb Ethernet, 2 x USB 2.0, Wi-Fi, Bluetooth, RTC w/Battery
    Other Features:
    Site: http://www.globalscaletechnologies.com/p-49-guruplug-server-standard.aspx
    Bare PCB: No
  25. GuruPlug Display
    CPU: ARMv5
    SOC: 800MHz Marvell ARMADA 168
    GPU: ??
    NOR Flash: 4Mb
    Storage: MicroSD Slot (w/ 4GB card), Internal MicroSD card – 8GB
    I/O: 1 x Ethernet 10/100 Mbps, 4 x USB 2.0 ports (Host),1 x USB 2.0 OTG micro-AB port (Device/Host),1 x MicroSD Socket (w/ 4GB card),1 x MicroSD Socket w/ JTAG I/F option, 1 x Internal MicroSD Socket (w/ 8GB card), 1 x Serial Port over USB (for console),1 x HDMI Output Port with CEC, RTC w/ Battery
    Other Features:
    Site:
    Bare PCB: No
  26. DreamPlug
    CPU: ARM9E
    GPU: ??
    NAND Flash: 4 GB
    Storage: eSATA, SD
    I/O: 2 x Gigabit Ethernet 10/100/1000 Mbps, 2 x USB 2.0 ports (Host),1 x eSATA 2.0 port- 3Gbps SATAII, 1 x SD Socket for user expansion/application, WiFi: 802.11 b/g/n, Bluethooth 3.0, JTAG, S/PDIF
    Other Features:
    Site: http://www.globalscaletechnologies.com/p-54-dreamplug-devkit.aspx
    Bare PCB: No
  27. D2Plug
    CPU: ARM v6/v7
    SOC: 800MHz Marvell PXA510
    GPU: ??
    NOR Flash: 16Mb SPI NOR FLASH
    Storage: SD, 1 x eSATAp, Powered eSATA & USB combo
    I/O: 1 x Ethernet 10/100/1000 Mbps, 2 x USB 2.0 Host port, 1 x eSATAp – Powered eSATA and USB 2.0 Host combo port, 1 x USB 2.0 Device port, 1 x SD card slot, 1 x HDMI 1080p Output port with CEC, 1 x VGA Output port, 1 x Audio Line OUT, 1 x MIC IN, 1 x S/PDIF optical out, WiFi: 802.11 b/g/n,Bluetooth 3.0 + HS, JTAG
    Other Features:
    Site: http://www.globalscaletechnologies.com/p-53-d2-plug.aspx
    Bare PCB: No
  28. Trim-Slice series
    CPU: dual-core ARM Cortex A9 @ 1 GHz
    SOC: NVIDIA Tegra 2
    GPU: GeForce GPU
    RAM Memory: 1 GB DDR2
    NAND Flash:
    Storage: SD, microSD, SATA, optional SSD or 2.5 HDD
    I/O: HDMI, optional DVI, S/PDIF 5.1, Stereo line-out, in, 4 USB 2.0, Micro USB device, Gigabit Ethernet, optional 802.11n, optional Bluetooth 2.0,optional video in, JTAG, UART
    Other Features:
    Site: http://trimslice.com/web/trim-slice-features
    Bare PCB: No
  29. Snowball
    CPU: 1GHz Dual Cortex A9
    SOC: STEricsson Nova A9500
    GPU: Mali 400
    NAND Flash: 4 / 8GByte e-MMC
    Storage: Micro-SD
    I/O: HDMI, CVBS, Audio, 10/100Mbits Ethernet, optional 802.11 b/g/n, Bluetooth 2.1+EDR, GPS, Built-in WIFI (removable antenna) 802.11 b/g/n, optional video in, JTAG, UART, Li-Ion Charger, RS232, Expansion Connectors, A lot of sensors
    Other Features:
    Site: ?? (cannot find the official site)
    Bare PCB: Yes
  30. i.MX53 Quick Start Board
    CPU: 1Ghz ARM Cortex™-A8
    SOC: Freescale i.MX535
    GPU: ??
    NAND Flash:
    Storage: SD/MMC, microSD
    I/O: VGA, LVDS, optional HDMI, 3-axis Accelerometer, JTAG, UART, SPDIF, 10/100 Ethernet, 2x high–speed USB Host port, 1x Micro USB Device port
    Other Features:
    Site: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX53QSB
    Bare PCB: Yes
  31. Pineriver H24/MiniX
    CPU: 1GHz Cortex-A8
    SOC: Allwinner A10
    GPU: Mali400
    RAM Memory: 512MB
    NAND Flash: 4GB
    Storage: Support External storage via USB host /Support External storage via TF card
    I/O: HDMI, CVBS, USB 2.0 host, USB OTG, Built-in WIFI module, Audio
    Other Features:
    Site: http://www.pineriver.cn/eshowProDetail.asp?ProID=1531
    Bare PCB: No
  32. Smallart UHOST
    CPU: ARM®Cortex™-A8@1.0GHz
    SOC: Allwinner A10
    GPU: Mali400
    RAM Memory: 1GB DRAM
    NAND Flash: 4 GB
    Storage: microSD
    I/O: HDMI, Wifi 802.11 b/g/n, Mini USB
    Other Features:
    Site: http://www.smallart.com.cn/en/pro.asp
    Bare PCB: No
  33. Genesi Efika MX Smarttop
    CPU: ARM Cortex-A8 800MHz
    SOC: Freescale i.MX515
    GPU: ??
    RAM Memory: 512MB RAM
    NAND Flash: 8GB
    Storage: 8GB Internal SSD
    I/O: HDMI, 2x USB 2.0, 10/100Mbit/s Ethernet, 802.11 b/g/n WiFi
    Other Features:
    Site: https://www.genesi-usa.com/store/details/11
    Bare PCB: No
  34. Embest DevKit8600
    CPU: 720MHz ARM Cortex-A8
    SOC: TI’s Sitara AM3359
    GPU: SGX530
    NAND Flash: 512MB
    Storage: SD Card
    I/O: 10/100/1000Mbps Ethernet, TFT LCD, VGA via module, USB2.0 OTG, USB 2.0 host, WiFi/Bluetooth Module, Debug, 4x serial, RS485, CAN, GPMC, JTAG, ADC, SPI, I2C, Audio in, Audio out, buttons
    Other Features:
    Site: http://www.armkits.com/product/devkit8600.asp
    Bare PCB: Yes
  35. Embest SBC8018
    CPU: ARM926EJ-S Core
    SOC: TI AM1808
    GPU: ??
    RAM Memory: 128MB Mobile DDR
    NAND Flash: 128MB
    Storage: SD card, SATA, SATAII
    I/O: LCD/Touch Screen interface, Two Camera interfaces, SPI, I2C, McBSP, 3x UART, GPIO, RTC w/ battery, buttons, 10/100Mbps Ethernet
    Other Features:
    Site: http://www.armkits.com/product/sbc8018.asp
    Bare PCB: Yes
  36. Embest SBC8530
    CPU: 1GHz ARM Cortex-A8
    SOC: TI DM3730
    GPU: ??
    RAM Memory: 512MB
    NAND Flash: 512MB
    Storage: SD Card
    I/O: UART, 4 USB Host, USB OTG, Ethernet, WiFi/BT, Audio, TF, Supports 24-bit TFT LCD, DVI-D and S-Video Output Display, Optional VGA, Camera, GPS, GPRS, WiFi and 3G Modules,10/100Mbps Ethernet
    Other Features:
    Site: http://www.armkits.com/product/sbc8530.asp
    Bare PCB: Yes
  37. Embest DevKit8500D
    SOC: DM3730
    GPU: POWERVR SGX
    RAM Memory: 512MB
    NAND Flash: 512MB, optional 2GB iNAND
    Storage:
    I/O: UART, 4 USB Host, USB OTG, Ethernet, Audio, TF, Keyboard, Jtag, Supports 24-bit TFT LCD, DVI-D and S-Video Output Display, Supports VGA, Camera, WiFi, GPS, GPRS, 3G Functions through Modules, 10/100M Ethernet
    Other Features:
    Site: http://www.armkits.com/product/devkit8500d.asp
    Bare PCB: Yes
  38. Cubieboard
    SOC: Allwinner A10
    GPU: Mali400
    RAM Memory: 512MB/1GB
    NAND Flash: 4GB
    Storage: 1 micro SD slot, 1 SATA
    I/O: HDMI, 2 USB Host, 96 extend pin including I2C, SPI, RGB/LVDS, CSI/TS, FM-IN, ADC, CVBS, VGA, SPDIF-OUT, R-TP, 10/100M Ethernet
    Other Features:
    Site: http://cubieboard.org/
    Bare PCB: Yes
Note: Base for this list is the PDF created by omgfire, I added information where missing and corrected information from the original specifications provided by the company or organization that created the device.
ЯegDwight
  • 101
ikku
  • 4,544
  • 26
  • 28
17
Raspberry Pi is quite enough hardware for XBMC. Most of the problems are in the XBMC software implementation, just wait them to be resolved.
However, raymii.org does have a nice list of Linux compatible PCs here: http://raymii.org/cms/p_Small_Linux_PCs_overview
http://java.net/downloads/mobileandembedded/Assets/SBC_comparison44-1.pdf
Zoot
  • 2,996
  • 36
Raspbmc worked great (with a bit safe overclocking) and in RC 5 there will be the new raspberry pi turbo mode.
Really the best option in my opinion ( I still have my HUGE HTPC but for the other TV's it's RaspBMC all the way)
ArchHaskeller
  • 1,435
  • 35
Shino
