12
pi@raspberrypi:/$ sudo apt-get update
Hit http://archive.raspberrypi.org wheezy InRelease
Hit http://mirrordirector.raspbian.org wheezy InRelease
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_US
Reading package lists... Error!
E: Problem parsing dependency Depends
E: Error occurred while processing libwww-mechanize-perl (NewVersion2)
E: Problem with MergeList /var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_main_binary-armhf_Packages
E: The package lists or status file could not be parsed or opened.
pi@raspberrypi:/$
I deleted the file mentioned
sudo rm /var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_main_binary-armhf_Packages
And reran the update, but it failed again after the download.
Cade Roux
  • 2,117
According to this blog post, and this askubuntu question you need to enter the following at the command line:
sudo rm /var/lib/apt/lists/* -vf
and then run
sudo apt-get update
Steve Robillard
  • 34,988
  • 106
  • 110
Hmm, this might be unrelated as it appears you solved your problem, however I found this page when I googled a similiar error:
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/dpkg/status
I had ignored the unzip error write error (disk full?) when I unzipped raspbian jessie to an sd card. The .img file was truncated to 4gb due to the size limitations of the fat32 filesystem. I went back and unzipped the image to an ext3 filesystem instead (ntfs would also work for >4Gb files), dd'd it and could then apt-get update.
briain
briain
