I've set up Avahi to have a static IP address (raspberrypi.local). For the time being I use an Ethernet cable for Raspberry Pi and Wi-Fi for Mac. Everything works fine connecting with my Mac:
ssh raspberrypi.local -l pi
Out of the blue, after eight hours more or less, I couldn't reach raspberrypi using ping nor ssh. I've cheched:
  • My computer does not have a firewall
  • Log in to SSH from the Raspberry Pi itself, ssh 127.0.0.1 -OK
  • Ping to www.google.com from both sides is OK
  • Restart Avahi daemon: sudo /etc/init.d/avahi-daemon restart
  • ifconfig confirms that I have set up the static IP correctly.
When I woke up today (after eight hours) it works again...curious.
Maybe it would be better to use the other approach for the static IP address (modifying the /etc/network/interfaces file).
Peter Mortensen
  • 2,004
darkZone
  • 105
I think, there is no way to have avahi assigning you a static IP address (an IP address looks something like 192.168.0.23 for IPv4 or 2001:DB8:F001:BEEF::23 for IPv6).
What you are probably talking about is the domain name, avahi is announcing to the network (raspberrypi.local). This domain name is resolved (translated) somewhere in the network to an IP address, because this IP address is the number your net is using to deliver the IP packets to the target.
The translation domain name => IP address is usually done by a Domain Name System Server (DNS Server). There usually is no DNS Server in a simple home network. Sometimes your Wifi router is doing some DNS stuff. But in your case, you are doing the name resolving stuff with avahi.
This is how avahi works:
The avahi daemon on your RPi is choosing some link local IP address (say 169.254.0.1, you should see this in your ifconfig output, link local addresses are always beginning with 169.254) and then it is sendig messages through the net, announcing: 169.254.0.1 should now be called raspberrypi.local.
These kind of messages are received by other avahi daemons or by zeroconf daemons on Macs. zeroconf will write on it's list: 169.254.0.1 is now called raspberrypi.local.
If you type ssh raspberrypi.local on your Mac, zeroconf will replace raspberrypi.local with 169.254.0.1 and ssh is talking to the correct machine.
It could be, that your RPi is selecting another IP address after a few hours (maybe because nobody talks to it?). And it seems like your Mac is not listening to the annunciation of the new address because it is sleeping, or there is a communication problem between avahi and zeroconf.
Solution:
I would recommend, not to rely on avahi / zeroconf as it is not 100% predictable. I am assuming that your network consists of a router and some devices (at least Mac and RPi). The router is a wifi router where your Mac is connected via wifi and the RPi is connected via ethernet cable. With this network you somehow need to make sure that the IP address of your RPi is always the same. After that, you can somehow map the IP to a domain name.
At first the IP address: You most probably have a DHCP server in your wifi router (this is a standard functionality of home wifi routers). The DHCP server is assigning dynamic IP addresses to the devices in your network. But only to the devices asking for one. To allow all the devices in your network to talk to each other, they all are in the same subnet. The subnet is most probably 192.168.0.0/24 or 192.168.1.0/24. This means, all addresses in your network are starting with 192.168.0. or 192.168.1. and only the part after the last point is changing. (Note: This is a different subnet than avahi and zeroconf are using. Every device can be in different subnets). To know the subnet, look at the first three parts of the IP address of your router, your Mac and/or your RPi.
To know where to reach your RPi from your Mac, you can do (for example) one of these four things:
  1. Setup a static IPv4 address on your RPi in /etc/network/interfaces or in NetworkManager. This address should be outside the range of addresses, your DHCP server (in your Wifi router) is using so that no other device will get the same address, sometimes you can configure this range. But the address needs also to be within the subnet, your Mac is in. The /etc/network/interfaces would look like
    iface eth0 inet static
      address 192.168.1.23
      netmask 255.255.255.0
      gateway 192.168.1.1
    gateway would be the address of your router, netmask the same as here, address: the same as the address of your router but with a different number after the last point. Remove other sections starting with iface eth0 inet.
  2. Setup the DHCP server to assign always the same IP address to your RPi. It will identify the RPi with its MAC address. You will have to enter it in the config interface of your router. You can find the RPi's MAC addres in the output of ifconfig look for a number like b8:27:eb:XX:XX:XX in the eth0 section.
  3. Setup a static IPv6 address on your RPi and on your Mac. This is my favorite option, as you don't have to care about DHCP ranges. But you will need a router that understands IPv6 and if you are using a switch, it needs to be a dumb link layer switch, or if it is a managed switch, it needs to understand IPv6.
    • Generate IPv6 Unique Local Address (ULA) with this tool or make one up. It will look like fdxx:xxxx:xxxx::/48.
    • Add a number after the last colon (fdxx:xxxx:xxxx::23) and put it in your RPiS' /etc/network/interfaces file after the other stuff:
      iface eth0 inet6 static
        address fdxx:xxxx:xxxx::23
        netmask 64
    • Add another number after the last colon (fdxx:xxxx:xxxx::42) and configure that in your Mac. I don't know how as I am not a Mac user. But most probably there is a /private/etc/network/interfaces file, or you can add a IPv6 ULA via the Network configuration UI.
  4. Tell your network's router to assign a domain name to your RPi (it will identify the RPi with its MAC address, assign a dynamic IP address via DHCP and resolve the domain name to this address). Not all routers have that functionality.
Assign a name to the fixed IP address, you configured in points 1, 2 or 3:
On your mac, you can add the ip address together with a name to your /private/etc/hosts file like
192.168.1.23 raspberrypi.local
or for the IPv6 address:
fdxx:xxxx:xxxx::23 raspberrypi.local
This would be enough to use raspberrypi.local to talk to your RPi with different programs. To simplify your life further more with SSH, you can also create a SSH config file in your user directory in USERDIR/.ssh/config. For the IPv4 address it would look like
Host raspberrypi.local
  HostName 192.168.1.23
  Port 22
  User pi
  IdentityFile ~/.ssh/id_rsa
or for the IPv6 address like
  HostName fdxx:xxxx:xxxx::23
  AddressFamily inet6
  User pi
you can omit the IdentityFile lines. Those are pointing to your SSH key. But if you use it and add the content of your Macs~/.ssh/id_rsa.pub file to your RPi's ~/.ssh/authorized_keys file, you can ssh to you RPi without entering a username or password, just:
Pascal Rosin
  • 539
Facing the same problem as you, I discovered that extensively ping-ing does bring up the wifi-connection again. I observed that after the 70-100th ping the Pi starts responding and after that an ssh-connection can be initiated successfully.
Edit Turn power save off
iw wlan0 set power_save off
Click here for details.
participant
  • 981
