9
I installed OpenCV 2.3.1 in my Raspberry Pi (Debian Wheezy) following this tutorial.
But I can't take video using my USB webcam. Gstreamer shows this error:
OpenCV Error: Unsupported format or combination of formats (Gstreamer Opencv backend doesn't support this codec acutally.) in CvVideoWriter_GStreamer::open, file /home/pi/OpenCV-2.3.1/modules/highgui/src/cap_gstreamer.cpp, line 483 terminate called after throwing an instance of 'cv::Exception' what(): /home/pi/OpenCV-2.3.1/modules/highgui/src/cap_gstreamer.cpp:483: error: (-210) Gstreamer Opencv backend doesn't support this codec acutally. in function CvVideoWriter_GStreamer::open Aborted
What can I do next?
Joel G
sumith
  • 623
The gstreamer tells you the stream is unsupported. FFMPEG is on like you said.
I had a look at the camera specifications- it comes out of laptop and is intended to work with Microsoft Windows mostly and not really supported for Linux but they say it will work on Redhat 2.+
That camera returns video in on of these codecs
  • YUY2 (FFMPEG OFF?)
  • MJPEG (FFMPEG ON?)
The still pictures is a standard JPG encoded by the MJPEG encoder, that's why you can see it. I am sure gstreamer supports MJPEG and not sure about YUV2. But! It is possible that the MJPEG implementation for ARM (Pi) architecture could still not be supported.
Possibly gstreamer needs to ask the camera for MJPEG directly or something else needs to ask for it. I doubt YUY2 will work any good on the Pi.(At least it is not listed in any supported codecs - but MJPG is)
It is possible that you should use something other than gstreamer. Take a look here. or at this post.
EDIT
OP resolved the problem by using image 2012-09-18-wheezy-raspbian and installing OpenCV 2.4.2 using this extensive and long guide.
Piotr Kula
  • 17,336
  • 66
  • 105
Raspberry pi is working with e-con ECAM 32 web cam now. I changed the voltage regulator which delivering 3.3v to camera , and connected TPS736xx voltage regulator from Texas instruments and now camera taking 320x240 pixel images and video...
Thank you very much for you supports...
sumith
  • 623
