I expect that the issue is that your Raspberry Pi is using different resolution to your TV.
The resolution can be changed manually by editing the Raspberry Pi config file which is located at /boot/config.txt
You must enter an hdmi_group and hdmi_mode in that file in order to set the resolution. The values that correspond to the resolution you want can be found half way down this wiki page.
For example:
hdmi_group=2
hdmi_mode=35
Would give you a resolution of 1280x1024 at 60Hz
CEA:
Electronic Industries Alliance (EIA-861B) refers to a CEA/EIA standard
which consists of display timing and formats supported by Digital
Televisions
DMT:
Display Monitor Timings (DMT) are a list of VESA standard pre-defined
timings which are commonly used within the Computer industry.
This leads me to believe that CEA (hdmi_group=1) should be used for televisions. Whereas DMT (hdmi_group=2) should be for computer monitors.
