Has anybody already connected some Grove Components to the Raspberry Pi?
How do I connect the system? And where can I find code tor program it?
hifkanotiks
  • 1,901
  • 28
rdmueller
  • 287
Grove is a system of some nicely packaged sensors designed to be used with SeeedStudio's Grove shields for Arduino. Since many of them are analogue sensors, you'd need an external ADC for the Raspberry Pi. Alternatively, you could attach an Arduino and communicate through that.
scruss
  • 9,117
  • 25
  • 36
Might be an old post but incase anyone finds this without knowing - the grovePi came about to solve this I think: http://www.dexterindustries.com/GrovePi/
pacifist
  • 121
This github repo also shows how to connect a single Grove sensor directly to a Raspberry Pi, however their examples will only work with a limited set of their sensors (I assume only digital sensors).
https://github.com/Seeed-Studio/Grove-RaspberryPi
bovine
  • 111
What really makes it easy to connect Grove Connectors to the Raspberry Pi, is to add a Grove shield to the Raspberry Pi, like the Pi2Grover connector.
Then it becomes plug and play with all your Python drivers available.
Here is a tutorial on how to use the devices: Tutorial: Intro to Grove Connectors for Arduino/Raspberry Pi Projects.
Greenonline
  • 2,969
  • 38
Faraday
