296
I'm not all that keen to buy a USB hard disk, but I'm aware that SD cards aren't suitable for many repetitions of reading and writing.
Are there any steps I can take to extend the life of my SD card while it's being used by my Raspberry Pi?
Highly Irregular
  • 5,789
  • 34
  • 40
14 Answers14
279
These methods should increase the lifespan of the SD card by minimising the number of read/writes in various ways:
Disable Swap
Swapping is the process of using part of the SD card as volatile memory. This will increase the amount of RAM available, but it will result in a high number of read/writes. It is unlikely to increase performance significantly.
Disable swap with the swapoff command:
sudo swapoff --all
You must also prevent it from coming back after a reboot:
  • For Raspbian which uses dphys-swapfile to manage a swap file (instead of a "normal" swap partition) you can simply sudo apt-get remove dphys-swapfile to remove it permanently. Best to remove because setting the CONF_SWAPSIZE to 0, as explained in this answer, doesn't seem to work and still creates a 100MB swap file after reboot.
  • For other distributions that use a swap partition instead of a swap file, remove the appropriate line from /etc/fstab
Disabling Journaling on the Filesystem
Using a journaling filesystem such as ext3 or ext4 WITHOUT a journal is an option to decrease read/writes. The obvious drawback of using a filesystem with journaling disabled is data loss as a result of an ungraceful dismount (i.e. post power failure, kernel lockup, etc.).
You can disable journaling on ext3 by mounting it as ext2.
You can disable journaling on ext4 on an unmounted drive like this:
tune4fs -O ^has_journal /dev/sdaX
e4fsck –f /dev/sdaX
sudo reboot
The noatime Mount Flag
Assign the noatime mount flag to partitions residing on the SD card by adding it to the options section of the partition in /etc/fstab.
Reading accesses to the file system will no longer result in an update to the atime information associated with the file. The importance of the noatime setting is that it eliminates the need by the system to make writes to the file system for files which are simply being read. Since writes can be somewhat expensive as mentioned in previous section, this can result in measurable performance gains. Note that the write time information to a file will continue to be updated anytime the file is written to with this option enabled.
Directories in RAM
Highly used directories such as /var/tmp/ and possibly /var/log can be relocated to RAM in /etc/fstab like this:
tmpfs /var/tmp tmpfs nodev,nosuid,size=50M 0 0
This will allow /var/tmp to use 50MB of RAM as disk space. The only issue with doing this is that any drives mounted in RAM will not persist past a reboot. Thus if you mount /var/log and your system encounters an error that causes it to reboot, you will not be able to find out why.
Directories in external Hard Disk
You can also mount some directories on a persistent USB hard disk. More details of this can be found in this question.
The Raspberry Pi can also boot its root partition from an external drive. This could be via USB or Ethernet and means that the SD card will only be used to delegate to different device during boot. This requires a bit of kernel hacking to accomplish, as I don't think the default kernel supports USB storage. You can find more information at this question, or this external blog post.
Jivings
  • 22,656
  • 94
  • 140
92
If the options provided by Jivings aren't possible for your application then another option to extend it's life substantially is to use an SD card which is much bigger than you need.
Leave plenty of free space
Most decent SD cards use wear levelling algorithms to minimise the number of times each block is written, so if the SD card is bigger than you need the wear can be spread over a much larger area of free space.
Part of the reason wear levelling is so important is that some file systems, such as FAT (the default format for many SD cards), hammer the same sectors over and over again.
For more information on this, see the answers to the question Is it true that a SD/MMC Card does wear levelling with its own controller? over on Electronics Stack Exchange, especially this answer.
One interesting statistic from this answer is that
taking a 2GB card and writing it beginning to end over and over again averages about 10TB before the card is dead and no longer is writable.
But the worrying thing is that
SD cards will not let you know when data is bad, i.e. wont return an I/O error like a PC harddrive will.
This may make your choice of file system important if you need to guarantee reliable storage.
One final note: Doubling the size of the SD card could more than double the longevity of it.
I.e. if you have a 2 GB SD card with 200 MB free then switching to a 4 GB card will give you 11 times the free space, wear levelling capacity and thus longevity, while switching to a 16 GB card will give you 71 times the free space.
Mark Booth
  • 4,410
  • 43
28
The only thing I see is to NOT swap on the SD card.
Swapping on the Sd card is probably what could kill your SD card.
If you need more RAM, you can try to use zram, theres a post on http://raspberry.pi.gw.gd/t50-Using-ZRAM.html giving some details about using ZRAM on the raspberry pi
More info for zram on http://en.wikipedia.org/wiki/ZRam
Also the most recent SD cards are know to be much more solid than older ones, buying a brand new class 10 SD card is probably a good option is you want to see it last a long time.
neofutur
  • 380
Most people here talk about their assumptions and not fom personal experience.
I have been using my RaspberryPi with RasPBX as a company switchboard with 8 extensions and a fax. We have 3 ip based trunks and one landline through LinkSYS SPA3000. It took only 1 month for my initial Kingston 4 GB SDCard to bite the dust.
I was still experimenting and did not have a backup. BTW the Pi is connected to an APC UPS. I then re-setup the entire RasPBX from the scratch, but this time I moved /var/log and /var/lib/mysql to our corporate NAS. This SD was Still OK after 3 months.
Then we had a very hot summer. During the third month the pi started not to detect the ethernet out of the blue. Then one day I found it all Leds are dim and it would not boot.
I've replaced the Pi with a fresh out of the box working one. The out of order one started to work after cooling down but it works rather erratic and when it boots to RasPBX the video mode won't switch to graphics, it stays in 80*25 Text. It was really messed up. I've ordered a heatsink set since. The new Pi works with it now for more than 2 months 7/24.
So if you will use the pi in a 7/24 environment, don't be cheap - buy heatsink and avoid using /var/log and other busy directories over the SD CARD.
Bex
  • 2,929
  • 26
  • 34
Kerem Ersoy
  • 197
You could try running Puppy Linux which is completely ram-resident. It's very small and blindingly fast since it runs completely in memory by copying the storage image (on SD card in your case) into RAM at boot and then flushing changes periodically back to storage. The frequency of this save is user controlled including manually.
Puppy uses the layered aufs or older unionfs filesystem with any of the standard Linux filesystems like ext3 or ext4. It can also reside on FAT, or NTFS partitions.
There are at least a couple of versions of Puppy specifically designed for the RPi, one of them created by the "Puppy Master", Barry Kauler.
For more, go to http://wikka.puppylinux.com/Puppi
DocSalvager
  • 261
I have compared all solutions the utilitze TMPFS and the best answer is a synthesis of the script prepare-dirs (see http://grenzdebiel.dyndns.org/wordpress/?p=98) with a proper /etc/defaults/tmpfs ((see http://www.a-netz.de/2013/02/ramdisks-for-the-raspberry/).
The necessary steps to perform on raspbian are:
1. edit /etc/default/tmpfs and set:
RAMLOCK=yes
RAMSHM=yes
RAMTMP=yes
I'd recommend the following sizes:
TMPFS_SIZE=10%VM
RUN_SIZE=10M
LOCK_SIZE=5M
SHM_SIZE=10M
TMP_SIZE=25M
2. enable additional directories using /etc/fstab
tmpfs   /var/log                tmpfs   size=20M,defaults,noatime,mode=0755 0 0
tmpfs   /var/cache/apt/archives tmpfs   size=100M,defaults,noexec,nosuid,nodev,mode=0755 0 0
tmpfs   /var/spool/cups         tmpfs   size=100M,defaults,noatime,mode=0755 0 0
tmpfs   /var/spool/cups/tmp     tmpfs   defaults,noatime,mode=0755 0 0
3. use the script /etc/init.d/prepare-dirs to create missing directories in /var/log so that all daemons start
See at the end what it contains in my case.
4. Make the script executable chmod 755 /etc/initd/prepare-dirs.
5. Make sure that the script will be started first on boot before your daemons start: update-rc.d prepare-dirs defaults 01 99
contents of /etc/init.d/prepare-dir:
#!/bin/bash
### BEGIN INIT INFO
# Provides:          prepare-dirs
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Required-Start:
# Required-Stop:
# Short-Description: Create needed directories on /var/log/ for tmpfs at startup
# Description:       Create needed directories on /var/log/ for tmpfs at startup
### END INIT INFO
# needed Dirs
DIR[0]=/var/log/lighttpd
DIR[1]=/var/log/cups
DIR[2]=/var/log/apt
DIR[3]=/var/log/ConsoleKit
DIR[4]=/var/log/fsck
DIR[5]=/var/log/news
DIR[6]=/var/log/ntpstats
DIR[7]=/var/log/samba
DIR[8]=/var/log/lastlog
DIR[9]=/var/log/exim
DIR[10]=/var/log/watchdog
case "${1:-''}" in
  start)
        typeset -i i=0 max=${#DIR[*]}
        while (( i < max ))
        do
                mkdir  ${DIR[$i]}
                chmod 755 ${DIR[$i]}
                i=i+1
        done
        # set rights
        chown www-data.www-data ${DIR[0]}
  stop)
  restart)
  reload|force-reload)
  status)
   echo "Usage: $SELF start"
   exit 1
esac
That's it.
abhisekp
  • 103
user13222
  • 141
These are my recommendations for a Debian 8.0 (Jessie)
They are based on iotop -bktoqqq and iostat -dzp 5. You should run these commands first to get an idea of the problem and its solution.
1. Disable swap
sudo systemctl disable dphys-swapfile
sudo rm /var/swap
2. Use mount options and RAM
Mount all partitions on the SD card with the noatime,commit=1800 options and mount the following directories to RAM with these entries in your /etc/fstab file:
/dev/mmcblk0p1  /boot           vfat    defaults,noatime,commit=1800  0       2
/dev/mmcblk0p2  /               ext4    defaults,noatime,commit=1800  0       1
tmpfs /tmp tmpfs size=50M,nodev,nosuid 0 0 tmpfs /var/tmp tmpfs size=10M,nodev,nosuid 0 0 tmpfs /var/cache/samba tmpfs size=5M,nodev,nosuid 0 0
Commit will delay the writes and collect them first.
3. Log the most frequent log files to /var/tmp/log/
See my description How can I reduce the writing to log files.
4. Stop Chromium from hammering the SD card
As it turns out Chromium writes heavily and cannot be stopped (see 176727, 52663). This effects the cache and the user data directory. The Chromium/Tips and tricks explain how this can be moved to RAM. Since the Raspberry doesn't have much RAM the suggested Tab Suspender is useful for saving RAM.
a) Cache
Limit the cache size and move it to RAM by editing /etc/chromium-browser/customizations/00-rpi-vars to
CHROMIUM_FLAGS="--disable-quic --enable-fast-unload --enable-tcp-fast-open --disk-cache-size=10000000 --media-cache-size=5000000"
Now the cache is small enough to be moved to the RAM disk by changing the XDG_CACHE_HOME entry in /etc/security/pam_env.conf to
XDG_CACHE_HOME  DEFAULT=/tmp/@{PAM_USER}/cache
Now my two users have a small browser cache in RAM. If that's not sufficient for you change the cache or /tmp/ size as necessary.
b) User data dir
Also the user data dir (.config/chromium/) experiences heavy writes. The Profile-sync-daemon is recommended by the Chromium/Tips and tricks. It was developed to manage your browser's profile in tmpfs and to periodically sync it back to your physical disc. Unfortunately the package is not yet part of the Raspbian 8.0 (Jessie) distribution. So I have not tested this yet.
5. Free space on the SD card
Free space by uninstalling packages and files you don't need. This should spread the wearing more evenly across your partitions.
Done!
Now run iotop -bktoqqq and iostat -dzp 5 again and see a significant reduction in the write access when the system is idle. Nothing gets written to my disk for many minutes. And don't worry about the green ACT LED flashing. Apparently it is not a good write access indicator.
Adam
  • 153
Frank Breitling
  • 1,009
  • 30
Disable Swapfile:
sudo dphys-swapfile swapoff
There is no necessity to uninstall, however if you are not using it, and do want the space, you can safely remove it. Alternate command to remove:
sudo dphys-swapfile uninstall
Usage: /sbin/dphys-swapfile {setup|swapon|swapoff|uninstall}
Flash Cell Endurance:
  • For Multi-Level Cell (MLC) Flash, up to 10,000 write cycles per physical sector.
  • For Single-Level Cell (SLC) Flash, up to 100,000 write cycles per physical sector.
  • Newer SSD offer 1 million write cycles per physical sector.
It is purely mathematical on large cards and normal wear. If you were to write to a 8GB MLC type flash card day and night over and over it would take about 30 days to kill it.
Episode 99 at Techsnap talks about wearing out SSD's and Allen explains how it is impossible to wear out a SSD in everyday usage and we do not need to worry about disabling swap, crons and all that. It just works now! The smart wear levelling takes care of everything.
Normal wear as quoted per Kingston should give you 27 years of life for the life in a professionals digital camera.
Which for normal DSLR cameras you might fill it up once every few months.. depends how much you travel. Taking into consideration a Pi, if you experiment allot and re flash often then it may take more of a toll. Usually once you are happy with a distro... you don't re flash it for months or years. So to prolong SD wear it would be good to follow some advice on reducing IO on the SD.
The price of flash has fallen and the technology is a lot better.
Most SD cards will outlive two or three generations of devices and by that time it will be considered to small and too slow to use with a much better and cheaper upgrade available!
Piotr Kula
  • 17,336
  • 66
  • 105
As mentioned before, the main issue are files and directories which are not worth being saved between reboots, but get written quite often, i.e. cache files, download folders, etc.
Raspbian as well as Debian and Ubuntu have a package called unburden-home-dir whose primary purpose is to symlink such files to a less problematic place like e.g. a tmpfs mount or an external harddisk which is less prone to wearing off.
It's commonly run at login time under X and targetted towards GUI application's cache files, but can also called from scripts or such and configured for arbitrary files in a user's home directory.
Axel Beckert
  • 1,240
Just a tiny reduction of write cycles can be reached by streaming the syslog output to another server. Of course, having such a server with a syslogd running is a precondition. However, with the Pi being a toy for Linux enthusiasts this is probably very often the case. :-)
To activate this streaming simply insert a statement like
*.*    @myserver.mydomain
at pretty much the top of the of the file /etc/rsyslog.conf, comment out all the other lines, and restart the logging by issuing service rsyslog restart. After this the messages should be coming in on the selected server.
One clear advantageous side effect of this is that you can easily monitor your Pi in conjunction with other machines on the same server. One downside is that during system startup and shutdown you may loose some messages when the network connection has not been established yet or has already been shut down.
Note: The 100,000 cycles limit is a hypothesis that applies to every computing device, even the keys in a keyboard.I believe running Pi in proper cooling conditions and proper shutdown/start cycles will give your better results rather than going into analogies.
Also this may augment my above opinion.
Add a new user in addition to user Pi[default]. Point the home directory of the new user in external drive[thumb/hard drive]. Give the new user, super-user permissions and start using it as your primary account.
I hope this helps..
touchStone
  • 227
Use busybox' syslog daemon (in the package busybox-syslogd on Raspbian/Debian/Ubuntu) instead of the default syslog daemon (usually rsyslog). By default on Raspbian/Debian/Ubuntu, the syslogd of busybox only logs into ring buffer in memory and not onto disk. The ring buffer has a size of 128kB by default, i.e. old log entries rotate out rather soon and are gone then. But you can configure it to use more RAM for it.
Nevertheless this is a far better solution than not having a syslog daemon at all, i.e. you can still log in and read the log entries of the approx. past few hours or days (depending on the configured size of the ring buffer) with the command logread. You can also use logread -f to get a tail -f like behaviour to e.g. only store interesting log entries using a filter script or to forward log entries over the network elsewhere, e.g. using stunnel or such.
Axel Beckert
  • 1,240
Couple of things I did:
chmod of the dphys-swapfile (somewhere in /etc - not near the PI at the moment) to:
sudo chmod a-x dphys-swapfile
I get minor errors on boot (can't start service dphys-swapfile) - Suppose there's a better way... rc-update??
Also, I capture images from the camera module, to eventually put on my webserver (the Pi). I formatted /dev/ram0 to ext2, mounted it as /media/ramdrive (using /etc/init.rc, I think). It's 4megs, big enough for one snap. No writes to SD.
The server (oululife.dnsdynamic.com) is experimental, but on the web. To really stress it out, I let it also stream an MP4 episode of 'Heartbeat*'. It runs lighttpd, Mysql, PHP, WordPress, and even when I remotely stream over the web it hardly breaks a sweat, load average about 0,2. No over-clocking at all. Model-B rev. 2, up 24/7. So, if I can get my logfiles into the other 15 /dev/ramX, I reckon my Micro-SD 16G card will last years....
Xen2050
  • 103
