I will be needing to access my Raspberry Pi while I am away from home, and SSH would be good for this purpose. I am using it with password authentication, and I don't want to mess around with SSH keys.
However, I don't want people to access the server using the default password, so I need to change the Raspberry Pi user password from "raspberry" to something else.
Peter Mortensen
  • 2,004
hifkanotiks
  • 1,901
  • 28
You can change the password of the current user by running passwd.
Related Questions
  1. How do I create a new user?
  2. What password to use to log in after the first boot?
Alex Chamberlain
  • 15,638
You can also use the raspi-config script. So run:
sudo raspi-config
A menu will pop up that allows a bunch of things, but if you look at the 4th thing down, select change_pass
change_pass        Change password for 'pi' user
kevin
  • 1,284
  • 26
sudo passwd pi for no prompt for current password, passwd for standard change. You can also use the graphical configuration tool or sudo raspi-config to change it, if you are using the default pi user.
Will
  • 371
