UPDATE
At some point, this started working after a kernel/firmware update, so it's not really a valid question any more (or else, the solution is "update your RPi")
Original question
I have a Raspberry Pi Model B running Raspbian, and I have an EDIMAX wireless adapter as well as an IOGEAR USB mouse. Both of them work fine when they are connected individually; however, if I connect them both at once, the mouse does not work at all, even though it is detected during boot and there are not any error messages. Both devices are connected to a self-powered USB hub.
I read something that said the RPi had problems when both a high and low speed device were connected at the same time, but there was a possible fix with a newer kernel/firmware. I have updated to the latest kernel and firmware using rpi-update, but the problem still exists. I also tried another suggestion which was plugging one device into the hub and the other directly into the RPi, but still no luck.
Is there something else I can try to get both of these working at the same time?
dmesg output:
[ 3.988029] usb 1-1.3.1: new low-speed USB device number 5 using dwc_otg
[ 4.122236] usb 1-1.3.1: New USB device found, idVendor=093a, idProduct=2510
[ 4.145138] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.160450] usb 1-1.3.1: Product: USB OPTICAL MOUSE
[ 4.173086] usb 1-1.3.1: Manufacturer: PIXART
[ 4.200932] input: PIXART USB OPTICAL MOUSE as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/input/input0
[ 4.247448] generic-usb 0003:093A:2510.0001: input: USB HID v1.11 Mouse [PIXART USB OPTICAL MOUSE] on usb-bcm2708_usb-1.3.1/input0
[ 64.971776] usb 1-1.3.1: USB disconnect, device number 5
[ 65.917781] usb 1-1.3.1: new low-speed USB device number 9 using dwc_otg
[ 66.192502] usb 1-1.3.1: New USB device found, idVendor=093a, idProduct=2510
[ 66.192550] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 66.192569] usb 1-1.3.1: Product: USB OPTICAL MOUSE
[ 66.192583] usb 1-1.3.1: Manufacturer: PIXART
[ 66.311300] input: PIXART USB OPTICAL MOUSE as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/input/input3
[ 66.312980] generic-usb 0003:093A:2510.0004: input: USB HID v1.11 Mouse [PIXART USB OPTICAL MOUSE] on usb-bcm2708_usb-1.3.1/input0
lsusb output:
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 009: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 006: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 007: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 008: ID 04d9:1603 Holtek Semiconductor, Inc. Keyboard
