A Skype video call would be a perfect solution, but I know Skype isn't designed for ARM processors. I just need something that can stream video and audio between the Pi and another computer running Linux or Windows. The video only needs to go FROM the Pi, but I would like audio that flows both ways. Is there any way to do this?
I could make do with just video, if needed.
UV4L driver, on Raspberry Pi 2 now support HTML5 embedded video with very low latency.I have tested it and it works great with HD video, no more flash plugins! Gstreamer pipes, ffmpeg or CVLC!
Here are some more documentation about it, compatible with Pi1 also but with a few caveats.
Piotr Kula
  • 17,336
  • 66
  • 105
There are a few options on this similar question. Though raspivid and cvlc is a good simple start. Do this on the server:
/opt/vc/bin/raspivid -o - -t 0 2>/dev/null | /usr/bin/cvlc stream:///dev/stdin --sout "#rtp{sdp=rtsp://:8554/}" :demux=h264 2>/dev/null >/dev/null &
Then from any other device point vlc at rtsp://192.168.0.153:8554/ or whatever your raspberrypi IP is.
user1133275
  • 2,216
