I'm going to clone my 8GB SD card to my 16GB one. My current SD card 8GB Kingston SDHC Class 4, and my new one is 16 GB SanDisk Extreme 45MB/s SDHC Class 10.
I've attempted using Win32 disk imager, however I get CRC errors after it has completed the boot partition. So therefore I want to attempt to use dd and see if it works at all. I've had some experience with dd and I've been able to mount the outputted data to a .img file and then of course mount that image file when needed to access it. Question is, how do I re-add all the files and folders to the new SD card exactly how it was on my old one?
For example, the output of dd will likely be old.img. Therefore, I know just simply coping old.img to the new SD card won't work. I need the entire contents inside old.img to be on the SD card.
Thanks!
codaamok
  • 163
Use this command:
dd if=/dev/mmcblk0 of=/dev/mmcblk1 bs=4096 conv=notrunc, noerror This assumes mmcblk0 is the source SD card and mmcblk1 is the new one.
If you only have one SD slot you can make an image, which can also be used for backups.
dd if=/dev/mmcblk0 of=backup-MM-DD-YYY.img conv=notrunc, noerror Swap SD cards then:
 dd if= backup-MM-DD-YYYY.img
   of=/dev/mmcblk0 conv=notrunc, noerror
notrunc means do not truncate the output file, noerror means to keep going if there is an error.
Boot into your new SD card and select expand file system on raspi-config.
user60684
  • 203
CRC error when cloning SD card for RPi seem to be just Kingston SD cards issue - this can be found else where on the internet. DD (for Windows) does not work for me either - same CRC error like in Win32 Disk Imager. Try to use some "cloning" SW where you can ignore CRC check error - i.e. Partclone (http://www.partclone.org/usage/partclone.restore.php) - this one works for me or try Ghost2k3 - this one I did not try, but there is possibility to turn off CRC error check in the menu.
Dew-spec
Just use dd or the Window's disk imager to copy the image to the new card.
Then boot from the new card.
If you are using Raspbian you can then use raspi-config to expand the user partition to use the full card.
joan
  • 71,852
  • 76
  • 108
This happened to me when trying to copy a known working raspian SD card - win32 disk imager crashed with CRC errors. I was using a USB SD card reader. When I tried my laptop (DELL Core i3 Win 7 64bit) internal SD card reader it worked fine. I suggest you try a different SD card reader.
DaveB
