28
I know this question has been asked before, but I can't find a fix for my problem, I just can't get my script to run on startup. Here's my script:
#!/bin/bash
iptables -A INPUT -m state --state NEW -p tcp --dport 22 -j ACCEPT
iptables -A OUTPUT -m state --state NEW -p tcp --sport 22 -j ACCEPT
I put it into the /etc/init.d directory
Made sure it had executable by using chmod 755 /etc/init.d/iptables.sh
And done touch /etc/rc3.d/S01iptables.sh
But nothing :( ... Any suggestions?
[ Nov 2017 ] The accepted answer here should be considered obsolete, please see https://raspberrypi.stackexchange.com/a/75057/5538
5 Answers5
30
You could also set up a cronjob (see tutorial) to make it run at startup
(sudo) crontab -e
only add sudo if your script needs superuser privileges. Then add this to your crontab:
@reboot /path/to/script.sh
nagyben
  • 773
[Please see the note in the question regarding the obsolescence of this answer.]
Try using this command to ensure your script is added to the boot sequence:
sudo update-rc.d /etc/init.d/nameofscript.sh defaults
Note that you can make a script executable using the +x option with chmod:
chmod +x /etc/init.d/nameofscript.sh
Steve
  • 1,431
You can add your script executable command to the bottom of .bashrc that will run your script every time you log in.
  1. Make sure you are in the pi folder:
    $ cd ~
  2. Create a file and write a script to run in the file:
    $ sudo nano superscript
  3. Save and exit: Ctrl+X, Y, Enter
  4. Open up .bashrc for configuration:
    $ sudo nano .bashrc
  5. Scroll down to the bottom and add the line: ./superscript
  6. Save and exit: Ctrl+X, Y, Enter
If you are looking for a solution that works on bootup to the console, take a look at this link. Basic rundown:
  1. Create a file for your startup script and write your script in the file:
    $ sudo nano /etc/init.d/superscript
  2. Save and exit: Ctrl+X, Y, Enter
  3. Make the script executable:
    $ sudo chmod 755 /etc/init.d/superscript
  4. Register script to be run at startup:
    $ sudo update-rc.d superscript defaults
If you want a script to run when you boot into the LXDE environment, you could take a look at this Raspberry Pi forum post:
  1. Navigate to ~/.config/lxsession/LXDE-pi
  2. Open the autostart file in that folder:
    $ sudo nano autostart
  3. Add @bash /path/to/scriptname & on a new line. If you want to run something like a python script, put something like @python mypython.py on a new line. Running a script file would be @./superscript, but for some reason the script runs in an infinite loop (perhaps this will stop that).
  4. Save and exit: Ctrl+X, Y, Enter
  5. Restart your Raspberry Pi into the LXDE environment.
taken from Execute script on start-up
Liam Giannini
  • 659
I usually just add the line to execute the script in /etc/rc.local, e.g. /path/to/my/script.sh &, before the last line that has exit 0. I added the "&" in order to send the script to the background in case it does not return, otherwise the next commands would not be executed.
So in your case I would simply add the two lines
at the end of /etc/rc.local just before exit 0.
George
  • 111
first of all create the script for me it's startup_file.sh
move startup_file.sh to /etc/init.d/
make sure it is executable by : sudo chmod +x /etc/init.d/startup_file.sh
now use this command: sudo update-rc.d startup_file.sh defaults
this one was suggested by goldilocks:
sudo update-rc.d /etc/init.d/startup_file.sh defaults ; it didn't work for me !!
just try one of the two should work
