I've tried:
installing different versions of the Raspberry PI os (Lite and Full, both 32 and 64 bit);
Editing cmdline and config in bootfs for ethernet connection (in
cmdlineaddedmodules-load=dwc2,g_ether, inconfig.txtaddeddtoverlay=dwc2)Creating
wpa_supplicant.conffile to connect to local wifi.
But neither of this things worked. If i connect Zero 2w to the desktop (regardless of the OS on the desktop device), is says "Network cable unplugged"
If i try to connect it to local wifi, it also does not work. Just nothing happens
Update 1: I see this strange line in the journalctl logs. Maybe, it is the problem, but i still don't know how to fix it
May 13 09:29:25 zero2w NetworkManager[492]: <info> [1747096165.3881] manager[0x55c1d25000]: rfkill: Wi-Fi hardware radio set disabled
Update 2: It looks like the problem lies in the recent Raspberry Pi OS update. If you struggle to connect your device to the network, consider downgrading to the legacy versions of the raspberry pi os
