So, I put my Pi on a custom quadcopter. I have a program that will track an object with a cam and send out pulse widths to control my motors. Anyway, right now I have to ssh into my Pi to run my executable. I am using a WiFi dongle to connect with ssh, but that thing is sucking a lot of current, so I need to get rid of it. I would like it to run my makefile executable on power up, instead of having to ssh in and run it each time I want to fly. I already have the Pi auto-logging in. The makefile is compiled and ready to go with sudo ./MyProg. Any thoughts?
Put your command into the /etc/rc.local file. You don't have to use sudo because this file is run by init at boot time.
If you encounter problems doing this, see:
If the program is persistent (i.e., keeps on ticking) be certain to background it. If it does not have such a feature built in, use & at the end of the line. If you do not do this, likely your boot will snag for a bit then init will kill the process.
- 3,748
- 1
- 21
- 17
You can just run sudo crontab -e and add the @reboot prefix to the command. For example if you wanted to run bash /home/pi/script.sh on boot, simply add @reboot bash /home/pi/script.sh to the end of your crontab file. Remember that crontab is user specific and may require sudo and a full path of execution.
- 6,365
- 8
- 38
- 63
- 209
- 1
- 5
For starting programs at boot time, another solution is to use systemd. This has the advantage of starting and stopping the program as well as just start on boot. A sample video tutorial illustrating how to use systemd is available here:
https://www.youtube.com/watch?v=eEuViHanjKI
There are also many other resources available by searching on "systemd".
- 1,794
- 2
- 16
- 28
