10
I use the rt2800usb driver (with a RT5370 USB dongle) and configurated my Raspberry Pi as a WiFi hotspot with hostapd. The problem is, that I get periodically timeouts (see example). This wouldn't be a problem if I wouldn't use my RPi as a remote control for a quadcopter. It seems to be independent on how I power my RPi and it happens with all Ralink wifi dongles of this type I have.
Antwort von 192.168.42.1: Bytes=32 Zeit=1ms TTL=64
Zeitüberschreitung der Anforderung.
dmesg output:
[ 2606.960813] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 6 in queue 2
[ 2606.960897] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 6 in queue 2
[ 2606.960925] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 6 in queue 2
[ 2606.961001] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 7 in queue 2
[ 2606.961052] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 8 in queue 2
[ 2606.961093] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 9 in queue 2
[ 2606.961133] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 10 in queue 2
[ 2606.961174] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 11 in queue 2
[ 2608.352291] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
[ 2608.352524] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
[ 2608.352766] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
[ 2608.353014] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
[ 2608.353262] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
[ 2608.353511] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
I prepared a small graphic as illustration. I implemented my own ping function (with variable timings for testing reasons) and see every ~12s a timeout (indicated in red by a small gap). I believe the normal user will not notice these timeouts, when just surfing in the internet.
dgrat
  • 223
It seems to be a known problem. From what I've found, all we can do is:
# disable power management (may need to be done periodically?)
iwconfig wlan0 power off
and disable hw encryption (so it will be done in the software). Edit or create /etc/modprobe.d/rt2800usb.conf :
options rt2800usb nohwcrypt=1
Also don't forget to update /lib/firmware/rt2870.bin according to this article http://www.raspberrypi.org/forums/viewtopic.php?t=22623 from MediaTek website!
Firmware versions for your reference:
md5:36c944c3138125605d28c0a3a1338be9 version 0.29 from Raspian base install
md5:ac4f6d8b679945208a978e397c016aa7 version 0.33 from DPO_RT5572_LinuxSTA_2.6.1.3_20121022 (MediaTek website)
Firmware version is printed on bootup to dmesg in the line containing:
rt2x00lib_request_firmware: Info - Firmware detected - version:
k3a
  • 208
After updating to the latest kernel, I've gone 4 hours without hitting nearly as many of these errors. Use rpi-update to update your kernel.
For reference, my uname -a is:
Linux boat-pi 3.12.28+ #713 PREEMPT Fri Sep 19 16:43:32 BST 2014 armv6l GNU/Linux
I still get rt2800usb_entry_txstatus_timeout error occasionally, but it used to fill my dmesg. I no longer get the Got TX status for an empty queue errors.
Update:
Spoke too soon. My pi was much better for 7 hours then started getting a flood of errors again. Haven't been able to figure out what triggers the error floods. Looks like the issue isn't confined to Raspberry Pi (also on OpenWRT, Fedora, Kernel.org). Seems like some people are reporting that everything is normal for a certain amount of time before the errors kick in.
johnboiles
  • 101
I updated the kernel (from Linux alarmpi 3.12.26-2-ARCH to Linux alarmpi 3.12.28-2-ARCH) this morning and since got my journal filled with
May not be a clean fix, but downgrading the kernel to its previous version made things work again (more than 7 hours later)
leon
I'm using a raspberry b+, linux 3.12.32+, with wipi wifi-dongle. The pi is inside an audio pre-amplifier, with the wifi-dongle connected from the outside through an extension usb-cord (panel mounted type A). It's critical that the usb-cord ground is firmly connected to the chassis of the pre-amp. Otherwise, we get exactly the error messages as shown in the question. Have not seen any improvement on this with newer rasbian or updated versions of rt2870.bin (tested v0.36). So, in some environments, the dmesg error messages can be due to radio pollution in the close proximity of the wifi radio device (motors generate frequencies that can disturb radio devices). Try to maximize the distance between the radio and the disturbance and/or improve radio shield.
Alexander
  • 463
