Yesterday, I tested a Nema 17 stepper motor with a DRV8825 motor driver. Connected to a Pi Pico 2 W using MicroPython on VS Code. It worked as intended, the motor spinned both directions. I took a picture so I could rebuild the circuit the next day at home.
The next day comes, and the motor doesn't work after rebuilding the circuit. It just moves 1 step every 8 seconds about. I tried changing to a new DRV8825, readjusting the current limit, changing wires, changing the circuit, resetting the Pi, but it still does the same problem. I measured with the multimeter, and the coil is alternating between 12V and -12V every 12 seconds about. I then tried on an Arduino UNO, and that seems to work fine. I didn't change anything to the circuit. I simply just moved to the Arduino whatever was connected to the Pi (DIR, STP, GRND, 5V RST+SLP), and coded on the Arduino IDE.
At this point, I'm don't know what's the issue as it works on the Arduino and it worked fine yesterday. My guess is that it has something to do with the fact that RST and SLP is connected to VSYS on the Pi.
Here's the circuit: Image of circuit
Here's the MicroPython code:
from machine import Pin
import utime
Define pin connections & motor's steps per revolution
dirPin = Pin(16, Pin.OUT) stepPin = Pin(17, Pin.OUT) stepsPerRevolution = 200
while True: # Set motor direction clockwise dirPin.value(1)
# Spin motor 4 revolutions slowly
for _ in range(4 * stepsPerRevolution):
    stepPin.value(1)
    utime.sleep_us(2000)
    stepPin.value(0)
utime.sleep(1)  # Wait a second
# Set motor direction counterclockwise
dirPin.value(0)
# Spin motor 4 revolutions quickly
    stepPin.value(1)
    utime.sleep_us(1000)
    stepPin.value(0)
Here's the Arduino code:
// Define pin connections & motor's steps per revolution
const int dirPin = 2;
const int stepPin = 3;
const int stepsPerRevolution = 200;
void setup() { // Declare pins as Outputs pinMode(stepPin, OUTPUT); pinMode(dirPin, OUTPUT); } void loop() { // Set motor direction clockwise digitalWrite(dirPin, HIGH);
// Spin motor 4 revolutions slowly for(int x = 0; x < 4 * stepsPerRevolution; x++) { digitalWrite(stepPin, HIGH); delayMicroseconds(2000); digitalWrite(stepPin, LOW); delayMicroseconds(2000); } delay(1000); // Wait a second
// Set motor direction counterclockwise digitalWrite(dirPin, LOW);
// Spin motor 4 revolutions quickly for(int x = 0; x < 4 * stepsPerRevolution; x++) { digitalWrite(stepPin, HIGH); delayMicroseconds(1000); digitalWrite(stepPin, LOW); delayMicroseconds(1000); } delay(1000); // Wait a second }
Julian
Try this short code.
import utime
dirPin.value(1) # Set direction
while True: stepPin.value(1) utime.sleep_ms(2) stepPin.value(0) utime.sleep_ms(2)
You should get a very slow continuous motion. If this doesn’t work, you likely have a hardware logic level or wiring issue.
tepalia
  • 151
