I'm running Raspbian GNU/Linux 12 (bookworm) on a Pi4. This is a headless system with SSH CLI only. I'm trying to add a Wi-Fi client connection in addition to Ethernet (which is working).
I tried this process which worked up to the point of reconfiguring the wlan0
$ sudo wpa_cli -i wlan0 reconfigure
Failed to connect to non-global ctrl_ifname: wlan0 error: No such file or directory
I saw this article link that said to run sudo ifconfig wlan0 up, but that does not solve it.
I tried the other suggestion in that link, which had this result:
$ sudo killall wpa_supplicant
$ sudo wpa_supplicant -i wlan0 -D wext -c /etc/wpa_supplicant/wpa_supplicant.conf -B
Successfully initialized wpa_supplicant
ioctl[SIOCSIWENCODEEXT]: Invalid argument
Searching on the error has not provided any answers.
The wlan part of ip a looks like this:
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 2c:cf:67:95:46:6d brd ff:ff:ff:ff:ff:ff
I also tried configuring using sudo raspi-config which fails with There was an error running option S1 Wireless LAN
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf contains:
update_config=1
country=US
network={
ssid="desired-open-ssid"
key_mgmt=NONE
sudo iwlist wlan0 scan|grep ESSID works and provides a list of SSIDs
