I was running Ubuntu 22.04 Server for Raspberry Pi. I just upgraded my release to Ubuntu 24.04 using the sudo do-release-upgrade command. Towards the end of the upgrade, I am getting the following errors:
dpkg: error processing package plymouth (--configure):
 installed plymouth package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of plymouth-theme-ubuntu-text:
 plymouth-theme-ubuntu-text depends on plymouth (= 24.004.60-1ubuntu7.1); however:
  Package plymouth is not configured yet.
dpkg: error processing package plymouth-theme-ubuntu-text (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup error from a previous failure.
Errors were encountered while processing: plymouth plymouth-theme-ubuntu-text E: Sub-process /usr/bin/dpkg returned an error code (1)
So I try this:
sudo apt-get upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
  libplymouth5
Use 'sudo apt autoremove' to remove it.
The following packages will be REMOVED:
  plymouth
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 1,262 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 330432 files and directories currently installed.)
Removing plymouth (24.004.60-1ubuntu7.1) ...
update-initramfs: Generating /boot/initrd.img-6.8.0-1020-raspi
Using DTB: bcm2711-rpi-4-b.dtb
Installing /lib/firmware/6.8.0-1020-raspi/device-tree/broadcom/bcm2711-rpi-4-b.dtb into /boot/dtbs/6.8.0-1020-raspi/./bcm2711-rpi-4-b.dtb
Taking backup of bcm2711-rpi-4-b.dtb.
Installing new bcm2711-rpi-4-b.dtb.
flash-kernel: deferring update (trigger activated)
update-initramfs: Generating /boot/initrd.img-5.15.0-1075-raspi
Installing /lib/firmware/5.15.0-1075-raspi/device-tree/broadcom/bcm2711-rpi-4-b.dtb into /boot/dtbs/5.15.0-1075-raspi/./bcm2711-rpi-4-b.dtb
update-initramfs: Generating /boot/initrd.img-5.15.0-1047-raspi
Couldn't find DTB bcm2711-rpi-4-b.dtb on the following paths: /etc/flash-kernel/dtbs /usr/lib/linux-image-5.15.0-1047-raspi /lib/firmware/5.15.0-1047-raspi/device-tree/
Installing  into /boot/dtbs/5.15.0-1047-raspi/./bcm2711-rpi-4-b.dtb
cp: cannot stat '': No such file or directory
run-parts: /etc/initramfs/post-update.d//flash-kernel exited with return code 1
dpkg: error processing package plymouth (--remove):
 installed plymouth package post-removal script subprocess returned error exit status 1
dpkg: too many errors, stopping
 plymouth
Processing was halted because there were too many errors.
Next I try this:
sudo dpkg --configure -a
Processing triggers for flash-kernel (3.107ubuntu13~24.04.2) ...
flash-kernel: installing version 6.8.0-1020-raspi
Taking backup of vmlinuz.
Installing new vmlinuz.
Taking backup of initrd.img.
Installing new initrd.img.
Taking backup of uboot_rpi_3.bin.
Installing new uboot_rpi_3.bin.
Taking backup of uboot_rpi_4.bin.
Installing new uboot_rpi_4.bin.
Taking backup of uboot_rpi_arm64.bin.
Installing new uboot_rpi_arm64.bin.
Generating boot script u-boot image... done.
Taking backup of boot.scr.
Installing new boot.scr.
Taking backup of start4.elf.
Installing new start4.elf.
Taking backup of fixup4db.dat.
Installing new fixup4db.dat.
Taking backup of start.elf.
Installing new start.elf.
Taking backup of start4x.elf.
Installing new start4x.elf.
Taking backup of fixup_x.dat.
Installing new fixup_x.dat.
Taking backup of start4db.elf.
Installing new start4db.elf.
Taking backup of start4cd.elf.
Installing new start4cd.elf.
Taking backup of fixup4cd.dat.
Installing new fixup4cd.dat.
Taking backup of fixup_db.dat.
Installing new fixup_db.dat.
Taking backup of fixup.dat.
Installing new fixup.dat.
Taking backup of bootcode.bin.
Installing new bootcode.bin.
Taking backup of fixup4x.dat.
Installing new fixup4x.dat.
Taking backup of start_db.elf.
Installing new start_db.elf.
Taking backup of fixup4.dat.
Installing new fixup4.dat.
Taking backup of fixup_cd.dat.
Installing new fixup_cd.dat.
Taking backup of start_cd.elf.
Installing new start_cd.elf.
Taking backup of start_x.elf.
Installing new start_x.elf.
Taking backup of bcm2710-rpi-3-b.dtb.
Installing new bcm2710-rpi-3-b.dtb.
Taking backup of bcm2712-rpi-5-b.dtb.
Installing new bcm2712-rpi-5-b.dtb.
Taking backup of bcm2711-rpi-400.dtb.
Installing new bcm2711-rpi-400.dtb.
Taking backup of bcm2711-rpi-cm4.dtb.
Installing new bcm2711-rpi-cm4.dtb.
Taking backup of bcm2710-rpi-cm3.dtb.
Installing new bcm2710-rpi-cm3.dtb.
Taking backup of bcm2712d0-rpi-5-b.dtb.
Installing new bcm2712d0-rpi-5-b.dtb.
Taking backup of hat_map.dtb.
Installing new hat_map.dtb.
Taking backup of bcm2711-rpi-cm4s.dtb.
Installing new bcm2711-rpi-cm4s.dtb.
Taking backup of bcm2710-rpi-zero-2-w.dtb.
Installing new bcm2710-rpi-zero-2-w.dtb.
Installing new dionaudio-kiwi.dtbo.
Taking backup of uart1-pi5.dtbo.
Installing new uart1-pi5.dtbo.
Taking backup of README.
Installing new README.
Then I try this:
sudo apt reinstall plymouth
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 134 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports noble-updates/main arm64 plymouth arm64 24.004.60-1ubuntu7.1 [134 kB]
Fetched 134 kB in 1s (124 kB/s)
(Reading database ... 330438 files and directories currently installed.)
Preparing to unpack .../plymouth_24.004.60-1ubuntu7.1_arm64.deb ...
Unpacking plymouth (24.004.60-1ubuntu7.1) over (24.004.60-1ubuntu7.1) ...
Setting up plymouth (24.004.60-1ubuntu7.1) ...
Processing triggers for runit (2.1.2-59ubuntu1) ...
Processing triggers for man-db (2.12.0-4build2) ...
 plymouth
Next this:
sudo apt purge plymouth-*
Note, selecting 'plymouth-themes-fade-in' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-kubuntu-logo' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-ubuntu-unity' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-lubuntu-logo' for glob 'plymouth-*'
Note, selecting 'plymouth-dev' for glob 'plymouth-*'
Note, selecting 'plymouth-drm' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-xubuntu-text' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-ubuntu-mate-logo' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-sabily-text' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-edubuntu' for glob 'plymouth-*'
Note, selecting 'plymouth-x11' for glob 'plymouth-*'
Note, selecting 'plymouth-disabler' for glob 'plymouth-*'
Note, selecting 'plymouth-themes-spinfinity' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-ubuntu-budgie-logo' for glob 'plymouth-*'
Note, selecting 'plymouth-label-ft' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-spinner' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-sabily' for glob 'plymouth-*'
Note, selecting 'plymouth-theme' for glob 'plymouth-*'
Note, selecting 'plymouth-themes-spinner' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-ubuntu-text' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-kubuntu-text' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-mobian' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-lubuntu-text' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-ubuntu-gnome-logo' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-ubuntu-mate-text' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-breeze' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-ubuntu-budgie-text' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-xubuntu-logo' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-phosh' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-ubuntucinnamon-spinner' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-hamara' for glob 'plymouth-*'
Note, selecting 'plymouth-label' for glob 'plymouth-*'
Note, selecting 'plymouth-themes-all' for glob 'plymouth-*'
Note, selecting 'plymouth-themes-script' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-ubuntustudio' for glob 'plymouth-*'
Note, selecting 'plymouth-themes-solar' for glob 'plymouth-*'
Note, selecting 'plymouth-theme-ubuntu-gnome-text' for glob 'plymouth-*'
Note, selecting 'plymouth-themes-glow' for glob 'plymouth-*'
Note, selecting 'plymouth-themes' for glob 'plymouth-*'
Package 'plymouth-dev' is not installed, so not removed
Package 'plymouth-drm' is not installed, so not removed
Package 'plymouth-theme-phosh' is not installed, so not removed
Note, selecting 'plymouth-themes' instead of 'plymouth-themes-all'
Note, selecting 'plymouth-themes' instead of 'plymouth-themes-fade-in'
Note, selecting 'plymouth-themes' instead of 'plymouth-themes-glow'
Note, selecting 'plymouth-themes' instead of 'plymouth-themes-script'
Note, selecting 'plymouth-themes' instead of 'plymouth-themes-solar'
Note, selecting 'plymouth-themes' instead of 'plymouth-themes-spinfinity'
Note, selecting 'plymouth-themes' instead of 'plymouth-themes-spinner'
Package 'plymouth-themes' is not installed, so not removed
Package 'plymouth-label' is not installed, so not removed
Package 'plymouth-theme-spinner' is not installed, so not removed
Package 'plymouth-theme-ubuntu-budgie-logo' is not installed, so not removed
Package 'plymouth-theme-ubuntu-budgie-text' is not installed, so not removed
Package 'plymouth-theme-edubuntu' is not installed, so not removed
Package 'plymouth-theme-breeze' is not installed, so not removed
Package 'plymouth-theme-kubuntu-logo' is not installed, so not removed
Package 'plymouth-theme-kubuntu-text' is not installed, so not removed
Package 'plymouth-theme-lubuntu-logo' is not installed, so not removed
Package 'plymouth-theme-lubuntu-text' is not installed, so not removed
Package 'plymouth-disabler' is not installed, so not removed
Package 'plymouth-label-ft' is not installed, so not removed
Package 'plymouth-theme-hamara' is not installed, so not removed
Package 'plymouth-theme-mobian' is not installed, so not removed
Package 'plymouth-theme-sabily' is not installed, so not removed
Package 'plymouth-theme-sabily-text' is not installed, so not removed
Package 'plymouth-theme-ubuntu-gnome-logo' is not installed, so not removed
Package 'plymouth-theme-ubuntu-gnome-text' is not installed, so not removed
Package 'plymouth-theme-ubuntu-mate-logo' is not installed, so not removed
Package 'plymouth-theme-ubuntu-mate-text' is not installed, so not removed
Package 'plymouth-theme-ubuntu-unity' is not installed, so not removed
Package 'plymouth-theme-ubuntucinnamon-spinner' is not installed, so not removed
Package 'plymouth-theme-ubuntustudio' is not installed, so not removed
Package 'plymouth-theme-xubuntu-logo' is not installed, so not removed
Package 'plymouth-theme-xubuntu-text' is not installed, so not removed
Package 'plymouth-x11' is not installed, so not removed
  plymouth-theme-ubuntu-text*
 plymouth
Then I try:
sudo apt install --fix-broken
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
 plymouth
Then I tried:
sudo apt-get install --reinstall dpkg
Need to get 1,265 kB of archives.
Get:1 http://ports.ubuntu.com/ubuntu-ports noble-updates/main arm64 dpkg arm64 1.22.6ubuntu6.1 [1,265 kB]
Fetched 1,265 kB in 1s (1,286 kB/s)
(Reading database ... 330516 files and directories currently installed.)
Preparing to unpack .../dpkg_1.22.6ubuntu6.1_arm64.deb ...
Unpacking dpkg (1.22.6ubuntu6.1) over (1.22.6ubuntu6.1) ...
Setting up dpkg (1.22.6ubuntu6.1) ...
 plymouth
Next I tried:
sudo apt --fix-broken install
 plymouth
Lastly I tried:
sudo apt-get install --reinstall lsb-release
Need to get 6,564 B of archives.
Get:1 http://ports.ubuntu.com/ubuntu-ports noble/main arm64 lsb-release all 12.0-2 [6,564 B]
Fetched 6,564 B in 0s (15.1 kB/s)
Preparing to unpack .../lsb-release_12.0-2_all.deb ...
Unpacking lsb-release (12.0-2) over (12.0-2) ...
Setting up lsb-release (12.0-2) ...
 plymouth
Nothing seems to work. I don't know how to properly remove and/or install/reinstall plymouth, or get it to work with apt. With a google search, it looks like there are a few other incidents like this out there, but there is no solution.
1)https://www.reddit.com/r/linuxquestions/comments/1e3q9to/plymouth_remove_error_after_upgrading_to_ubuntu/
  1. https://askubuntu.com/questions/892501/apt-get-command-returning-error-in-plymouth-theme-ubuntu-text
How can I fix my installation so that plymouth is properly removed OR installed, and apt works again? How can I debug this and fix my Ubuntu 24.04 Server so that it's working fully again?
DanRan
  • 99
