I'm trying to add the Updater plug-in to the right side of my taskbar.
I want the right side configuration to be:Updater, Bluetooth, Network, Clock.
When I add Updater, it is added to the bottom of the list (far right) and I can't figure out how to change it's location.
Raspberry pi 4b Bookworm with all updates Wayland
Thank you in advance
shs
The taskbar has changed in recent Raspberry Pi OS although the fundamentals are the same.
To change position select the Add/Remove Plugins
then select the added plugin in the Right Side stack.
You can use the Move left (to move up the stack) or Move right to reposition.
