The core affected package is libssl1.0.0, which if you can, just replace with the patched version, restart everything. You can try to download a binary, and manually install an arm-hf, using dpkg with the version 1.0.1e-2+deb7u5 for wheezy.
You can also use the jessie repository, just for this single one time update, which should get you version 1.0.1g-1.
After install and reboot you it is strongly recommended to revoke all keys and certificates and regenerate everything from scratch, using new passwords and vectors.
As of 09/04/2014 the main wheezy repository uses the patched version 1.0.1e-2+deb7u5 and as commented, you can get it like this:
> sudo apt-get update
> sudo apt-get upgrade
Which will update the following packages:
libssl1.0.0 openssh-client openssh-server openssl ssh
*Here is how to selectively upgrade certain packages using jessie repository, without completely breaking wheezy, and will install the latest g version
Add the following two lines into /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb http://archive.raspbian.org/raspbian jessie main contrib non-free rpi
You then edit the file /etc/apt/preferences (create the file if doesn't exist) to tell apt in which repositories it should look to do an update. We put jessie on a low priorty so that when you use apt-get update it will ignore jessie and use wheezy repo instead. This is important for the step after this one.
Package: *
Pin: release n=wheezy
Pin-Priority: 900
Package: *
Pin: release n=jessie
Pin-Priority: 300
Package: *
Pin: release o=Raspbian
Pin-Priority: -10
Now, at your free will you can tell apt to use jessie instead.
apt-get update
apt-get -t jessie install openssl libssl1.0.0 openssh-client openssh-server ssh
*An extract from Chapter 6, Raspberry Pi Server Essentials.
