I need to serialize objects to JSON. If I install mono from apt-get, serializing with JSON.net does not work.
I added this line into /etc/apt/sources.list:
deb http://debian.meebey.net/experimental/mono /
After this, i ran
sudo apt-get clean
sudo apt-get update
sudo apt-get upgrade -y
sudo apt-get install mono-complete
This version of mono supports serializing into JSON. If you dont add the line into sources.list, all serializations will fail, not only those with double values. When I have a double in a dictionary or in a list, this exception always gets thrown thy JSON.net.
Input string was not in the correct format
Here is some sample code, so you can try (you need to add a reference to JSON.net):
try { Console.WriteLine(3.14159265359f.ToString()); } catch (Exception ex) { Console.WriteLine(ex.Message); }
try { Console.WriteLine(3.14159265359d.ToString()); } catch (Exception ex) { Console.WriteLine(ex.Message); }
try { Console.WriteLine(Convert.ToDouble("3.14159265359").ToString()); } catch (Exception ex) { Console.WriteLine(ex.Message); }
try { Console.WriteLine(Convert.ToDouble("3,14159265359").ToString()); } catch (Exception ex) { Console.WriteLine(ex.Message); }
try { Console.WriteLine(JsonConvert.SerializeObject(3.14159265359f)); } catch (Exception ex) { Console.WriteLine(ex.Message); }
try { Console.WriteLine(JsonConvert.SerializeObject(3.14159265359d)); } catch (Exception ex) { Console.WriteLine(ex.Message); }
try { Console.WriteLine(JsonConvert.SerializeObject(new List<object>() { "test", DateTime.Now, 3.14159265359f, 3.14159265359d})); } catch (Exception ex) { Console.WriteLine(ex.Message); }
try { Console.WriteLine(JsonConvert.SerializeObject(new Dictionary<object, object>() {
    {"test", DateTime.Now},
    {DateTime.Now, 3.14159265359f},
    {3.14159265359f, 3.14159265359d},
    {3.14159265359d, "test"},
In my case, this results in
3,141593
3,14159265359
314159265359
I need to serialize and dictionary or an object where some properties are double numbers, but I dont know how to fix this error.
feedc0de
  • 229
This works for me on my Pi. I'm using a version of Mono that I compiled back in December before the patch for hard-float and Mono was released. Here's the output I get. I suspect that the issue has to do with the internationalization of the decimal point character.
Here is the output of mono --version:
Mono Runtime Engine version 3.2.7 (master/e42840f Thu Dec  5 11:31:03 EST 2013)
Copyright (C) 2002-2013 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
        TLS:           __thread
        SIGSEGV:       normal
        Notifications: epoll
        Architecture:  armel,vfp+hard
        Disabled:      none
        Misc:          softdebug
        LLVM:          supported, not enabled.
        GC:            sgen
I also manually downloaded Json.net and specifically referenced the NET20 dll.
johnma@raspberrypi ~/tpf$ $ mcs -r:Newtonsoft.Json.dll jsontest.cs
johnma@raspberrypi ~/tpf$ $ ./jsontest.exe
NumberFormatInfo.NumberDecimalSeparator = .
3.141593
3.14159265359
3.14159265359
314159265359
3.14159274
3.14159265359
["test","2014-04-11T16:32:29.975495-04:00",3.14159274,3.14159265359]
{"test":"2014-04-11T16:32:30.971131-04:00","00/735334/0001 16:32:30":3.14159274,"3.141593":3.14159265359,"3.14159265359":"test"}
Update: Success! I've recreated your problem!
I get your results when I run jsontest.exe using LANG=de_DE.UTF-8, see below:
johnma@raspberrypi ~/tpf$ $ LANG=de_DE.UTF-8 ./jsontest.exe
CultureInfo.CurrentCulture = de-DE
NumberFormatInfo.NumberDecimalSeparator = ,
3,141593
3,14159265359
314159265359
I suspect that this is most likely a bug or quirk in Mono. Clearly Convert.ToDouble("3,14159265359") is throwing an exception. I suspect that all other exceptions are due to the Double values being stored internally as String objects.
Can you run your exe using LANG=en_US.UTF-8?
Here's the source I compiled:
using System;
using Newtonsoft.Json;
using System.Collections.Generic;
using System.Globalization;
class MainClass
    public static void Main (string[] args)
        Console.WriteLine( "CultureInfo.CurrentCulture = "
                           + CultureInfo.CurrentCulture );
        NumberFormatInfo nfi = NumberFormatInfo.GetInstance(CultureInfo.CurrentCulture);
        Console.WriteLine( "NumberFormatInfo.NumberDecimalSeparator = "
                           + nfi.NumberDecimalSeparator );
Updated to add code to display NumberFormatInfo.NumberDecimalSeparator
HeatfanJohn
  • 3,115
  • 26
  • 38
