I have a Raspberrypi 5 running bookworm and would like to run a python script at reboot. The script is in a virtual environment: /home/mipi/venv/Startup/Startup.py (where venv is the root directory for the virtual environment). So far I have been unsuccessful. The script runs flawlessly in Thonny.
Ownership and permissions on the script are:
-rwxrwx--- 1 mipi mipi 3382 Dec  8 16:44 Startup.py
Can someone please explain to me how to get the script to run on reboot?
When I put the following into crontab -e:
@reboot service /home/mipi/venv/bin/activate && /home/mipi/venv/Startup/Startup.py
The following is in the system log file:
Dec 09 08:31:20 mipi CRON[542]: pam_unix(cron:session): session opened for user mipi(uid=1000) by (uid=0)
  Dec 09 08:31:20 mipi CRON[637]: (mipi) CMD (source /home/mipi/venv/bin/python /home/mipi/venv/Startup/Startup.py)
  Dec 09 08:31:20 mipi CRON[542]: (CRON) info (No MTA installed, discarding output)
  Dec 09 08:31:20 mipi CRON[542]: pam_unix(cron:session): session closed for user mipi
When I enter the following in crontab -e:
@reboot /usr/bin/sleep 30 source /home/mipi/venv/bin/python /home/mipi/venv/Startup/Startup.py >/dev/null 2>&1
The following is in the log file:
Dec 09 09:02:31 mipi CRON[545]: pam_unix(cron:session): session opened for user mipi(uid=1000) by (uid=0)
Dec 09 09:02:31 mipi CRON[637]: (mipi) CMD (/usr/bin/sleep 30 source /home/mipi/venv/bin/python /home/mipi/venv/Startup/Start>
Dec 09 09:02:31 mipi CRON[545]: pam_unix(cron:session): session closed for user mipi
I tried entering the following in sudo crontab -e:
@reboot source /home/mipi/venv/bin/activate && /home/mipi/venv/Startup/Startup.py
And this is what was in the log file:
Dec 09 09:33:57 mipi CRON[604]: (root) CMD (source /home/mipi/venv/bin/activate && /home/mipi/venv/Startup/Startup.py)
Dec 09 09:33:57 mipi CRON[605]: (mipi) CMD (/usr/bin/sleep 30 source /home/mipi/venv/bin/python /home/mipi/venv/Startup/Startup.py >/dev>
Dec 09 09:33:57 mipi CRON[538]: (CRON) info (No MTA installed, discarding output)
Dec 09 09:33:57 mipi CRON[538]: pam_unix(cron:session): session closed for user root
Dec 09 09:33:57 mipi CRON[539]: pam_unix(cron:session): session closed for user mipi
Ken
Upon further digging, I found this works:
/home/mipi/venv/bin/python /home/mipi/Startup/Startup.py
Ken
