I'm using a Raspberry pi 5, I'm having issues running ultralytics and PyQt5 at the same time. The way I installed ultralytics and PyQt5 are different. First I used
sudo apt install python3-pyqt5
, then created a virtual environment with --system-site-packages. So I can still access PyQt5 because for some reason using
pip install PyQt5
does not work in system wide and virtual environment. For ultralytics is used
pip install ultralytics[export]
When I run them separately they work but when I use them at the same time it does not work. I created an app the using PyQt5 for facial detect with the help of ultralytics and YOLO but this error shows when I run my code this error appears:
QObject::moveToThread: Current thread (0x193cbe0) is not the object's thread (0x7c9bcf0). Cannot move to target thread (0x193cbe0)
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "/home/admin/myvenv/lib/python3.11/site-packages/cv2/qt/plugins" even though it was found. This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: xcb, eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx.
Process ended with exit code -6.
Does anyone know how to deal with this?
