The Raspberry Pi 4B has 6 Uart Pins. I want to use at least two of them but dont get them to work.
ls -al /dev/ttyAMA*
crw-rw---- 1 root dialout 204, 64 Oct 17 00:03 /dev/ttyAMA0
dmesg | grep tty
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:01:EA:DD vc_mem.mem_base=0xec00000 vc_mem.mem_size=0x10000000 console=tty1 root=PARTUUID=8acf4fd7-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000882] printk: console [tty1] enabled
[ 1.576439] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.589642] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
[ 3.502245] systemd[1]: Created slice system-getty.slice.
dtoverlay -a | grep uart
midi-uart0
midi-uart1
midi-uart2
midi-uart3
midi-uart4
midi-uart5
miniuart-bt
qca7000-uart0
uart0
uart1
uart2
uart3
uart4
uart5
Here the /boot/config.txt
[all]
enable_uart=1 # Enable the UART subsystem
#dtoverlay=pi3-disable-bt # Disable Bluetooth if you want to use UART0
#dtoverlay=uart0 # Enable UART0
dtoverlay=uart1 # Enable UART1
dtoverlay=uart2 # Enable UART2
dtoverlay=uart3 # Enable UART3
dtoverlay=uart4 # Enable UART4
dtoverlay=uart5 # Enable UART5
