I have a problem with a new installed SSD on a raspberry pi 4, It is in some kind boot loop. Looking at /var/log/boot.log I see
------------ Thu Jul 04 01:17:10 BST 2024 ------------
e2fsck 1.47.0 (5-Feb-2023)
rootfs: clean, 144709/7185024 files, 1603451/29173110 blocks
[ OK ] Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
[ OK ] Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
[ OK ] Finished systemd-binfmt.service - Set Up Additional Binary Formats.
[ OK ] Finished systemd-tmpfiles-setup.service - Create Volatile Files and Directories.
Starting systemd-timesyncd.service - Network Time Synchronization...
Starting systemd-update-utmp.service - Record System Boot/Shutdown in UTMP...
[ OK ] Finished systemd-update-utmp.service - Record System Boot/Shutdown in UTMP.
[ OK ] Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
Starting modprobe@loop.service - Load Kernel Module loop...
[ OK ] Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[ OK ] Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
[ OK ] Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[ OK ] Finished modprobe@loop.service - Load Kernel Module loop.
[ OK ] Started systemd-timesyncd.service - Network Time Synchronization.
[ OK ] Reached target sysinit.target - System Initialization.
[ OK ] Reached target time-set.target - System Time Set.
[ OK ] Listening on dbus.socket - D-Bus System Message Bus Socket.
Starting alsa-restore.service - Save/Restore Sound Card State...
Starting bluetooth.service - Bluetooth service...
Starting kernel-command-line.service - Command from Kernel Command Line...
[FAILED] Failed to start kernel-command-line.service - Command from Kernel Command Line.
See 'systemctl status kernel-command-line.service' for details.
[DEPEND] Dependency failed for kernel-command-line.target - Command from Kernel Command Line.
[ OK ] Removed slice system-modprobe.slice - Slice /system/modprobe.
[ OK ] Stopped systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
[ OK ] Stopped target time-set.target - System Time Set.
The system boots and runs fine from a SDcard with buster. I had built the new SSD from the OS on the SDcard using
curl -O -J -O https://downloads.raspberrypi.com/raspios_arm64/ima\
ges/raspios_arm64-2024-07-04/2024-07-04-raspios-bookworm-arm64.img.xz
sudo rpi-imager --cli --debug --first-run-script rpred.config \
2024-07-04-raspios-bookworm-arm64.img.xz /dev/sda
My bootloader config, on the SD card, is "static" and the EEPROM is as follows
pi: sudo rpi-eeprom-update
BOOTLOADER: up to date
CURRENT: Thu 11 May 06:26:03 UTC 2023 (1683786363)
LATEST: Thu 11 May 06:26:03 UTC 2023 (1683786363)
RELEASE: stable (/lib/firmware/raspberrypi/bootloader/stable)
Use raspi-config to change the release.
VL805_FW: Dedicated VL805 EEPROM
VL805: up to date
CURRENT: 000138c0
LATEST: 000138c0
pi: vcgencmd bootloader_version
2023/05/11 07:26:03
version 4fd8f1f3f7a05f7756edb1d3f15ffd7e428981f5 (release)
timestamp 1683786363
update-time 1728970004
capabilities 0x0000007f
pi: sudo apt full-upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Anybody able to advise how I get this fixed.
PS> In response to a comment here is the rpred.config I attempted to use.
pi@raspberrypired:/mnt/SDcard/file/home/pi$ cat rpred.config
[pi]
hostname=raspberrypired
ssh_enable=true
