When I build PicoMiteWeb, which is a BASIC for PICO PI, I get this warning and some errors from the compiler.
#warning stdio USB was configured along with user use of TinyUSB device mode, but CDC is not enabled
I have no ideas how to solve it and the build errors it may produce.
This is the CMakeList.txt:
cmake_minimum_required(VERSION 3.13)
include(pico_sdk_import.cmake)
project(test_project C CXX ASM)
set(CMAKE_C_STANDARD 11)
set(CMAKE_CXX_STANDARD 17)
set(PICO_BOARD pico_w)
pico_sdk_init()
add_executable(PicoMiteWeb
PicoMite.c
regex.c
MMBasic.c
Operators.c
Custom.c
Functions.c
Commands.c
Memory.c
FileIO.c
ff.c
ffsystem.c
ffunicode.c
mmc_stm32.c
Draw.c
Editor.c
XModem.c
MM_Misc.c
External.c
MATHS.c
Onewire.c
I2C.c
SPI.c
Serial.c
SPI-LCD.c
BmpDecoder.c
Touch.c
GPS.c
Audio.c
CFunction.c
Keyboard.c
SSD1963.c
picojpeg.c
lfs.c
lfs_util.c
hxcmod.c
cJSON.c
mqtt.c
MMMqtt.c
MMTCPclient.c
MMtelnet.c
MMntp.c
MMtcpserver.c
tftp.c
MMtftp.c
MMudp.c
VS1053.c
set_source_files_properties(mmc_stm32.c PROPERTIES COMPILE_FLAGS -O2)
set_source_files_properties(ff.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(GUI.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(BmpDecoder.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(GPS.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(I2C.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(lfs.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(picojpeg.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(regex.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(hxcmod.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(MATHS.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(Editor.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(MMtls.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(cJSON.c PROPERTIES COMPILE_FLAGS -Os)
target_include_directories(PicoMiteWeb PRIVATE
${CMAKE_CURRENT_LIST_DIR}
${CMAKE_CURRENT_LIST_DIR}/.. # for our common lwipopts
pico_define_boot_stage2(slower_boot2 ${PICO_DEFAULT_BOOT_STAGE2_FILE})
target_compile_definitions(slower_boot2 PRIVATE PICO_FLASH_SPI_CLKDIV=4)
pico_set_boot_stage2(PicoMiteWeb slower_boot2)
Pico_enable_stdio_usb(PicoMiteWeb 1)
pico_enable_stdio_uart(PicoMiteWeb 0)
pico_add_extra_outputs(PicoMiteWeb)
target_compile_options(PicoMiteWeb PRIVATE -DPICOMITEWEB
-DNDEBUG
-DPICO_XOSC_STARTUP_DELAY_MULTIPLIER=64
-DPICO_STDIO_USB_ENABLE_RESET_VIA_VENDOR_INTERFACE=0
-DPICO_STACK_SIZE=0x1000
-DPICO_CORE1_STACK_SIZE=0x0
-DPICO_HEAP_SIZE=0x2000
-DPICO_CYW43_ARCH_POLL
-DCYW43_HOST_NAME="WebMite"
-Wall
-O2)
target_link_libraries(PicoMiteWeb
pico_stdlib
hardware_flash
hardware_irq
hardware_adc
hardware_pwm
hardware_i2c
hardware_spi
hardware_dma
hardware_exception
hardware_pio
pico_cyw43_arch_lwip_poll
In my understanding:
it should enable the stdin/out over USB, and this is confirmed by the first part of the warning message:
#warning stdio USB was configured...
It is unclear to me the second part of the warning message about the lack of CDC.
The Errors I'm getting are:
/home/pi/pico/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb_descriptors.c:53:24: error: 'TUD_CONFIG_DESC_LEN' undeclared here (not in a function); did you mean 'TUD_RPI_RESET_DESC_LEN'?
#define USBD_DESC_LEN (TUD_CONFIG_DESC_LEN + TUD_CDC_DESC_LEN)
/home/pi/pico/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb_descriptors.c:109:36: note: in expansion of macro 'USBD_DESC_LEN'
static const uint8_t usbd_desc_cfg[USBD_DESC_LEN] = {
/home/pi/pico/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb_descriptors.c:53:46: error: 'TUD_CDC_DESC_LEN' undeclared here (not in a function); did you mean 'USBD_DESC_LEN'?
I found the missing definition in pico-sdk/lib/tinyusb/src/device/usbd.h, however, I have not idea how to force the compiler to include it.
