17
How do I install Retropie on a Raspberry Pi that already has Raspbian installed?
At the very worst I can use BerryBoot if I need another OS.
recantha
  • 4,489
  • 26
givensnickel
  • 181
You can just run the RetroPie setup script and it will install all the dependencies for you.
Or can use berryboot to have a completely separate partition on your SD card.
Or you can just get another SD card and dedicate it to RetroPie.
Stevoisiak
  • 321
rob
  • 2,813
  • 22
install rasbian first then log on the desktop using startx and then install retro pi via the desktop consol using this method http://blog.petrockblock.com/2012/07/22/retropie-setup-an-initialization-script-for-retroarch-on-the-raspberry-pi/.
cj2tech
I would suggest the RetroPie setup script. I tried berry boot but had problems accessing the necessary files to modify the config and copy over roms. It also seemed a little slow, but that might have just been me.
Although it can take a while for the setup script to completely run, I'd suggest going that route.
Bill
