I would like to know, if it is possible to use a SSD as the only drive for a Raspberry PI.
The reason is, I would like to use it as database- and webserver and I am not sure about the lifetime of SD-cards.
You can boot from the SD card then just use an attached SSD, but you can not get around using the SD card for booting.
Once booted you can make the SD card read only and make sure all the software etc is running of the SSD
cmdline.txt contains root=/dev/mmcblk0p2 rootfstype=ext4 indicating the root partition.
I assume that if you used a SSD with a suitable partition you could use root=/dev/sda1 (or whatever). I have not tried this (and don't share the paranoia many seem to have about using SDCARDS).
It is not clear whether Raspbian contains the SSD trim support needed to ensure reasonable lifetime on a SSD.
It would be interesting to see if this works. I might even give it a go with a HD.
2020 answer:
As of recently (June 2020) booting from USB is out of "beta" but hasn't been announced as officially supported. Read all about it here
