Goal: configuring my RPi 4 to act as a bridge/router between the cafe wifi downstairs and my private network while also using Pi-hole for my local network. Effectively, my wlan0 connects to the cafe (WAN), and I have a TrendNet adapter wlan1 to broadcast my LAN. I am also trying to share wlan0 with eth0 for a NAS.
Was playing around with overclocking and one article advised running rpi-update, which I did sadly (ignoring its warnings as well as many other articles). I found out soon after that my TrendNet was not getting picked up and figured the new firmware was not compatible the old driver. No problem, I thought, as I tried to reinstall the driver but was met with Your kernel header files aren't properly installed.
I then followed steps to revert rpi-update using sudo apt-get install --reinstall raspberrypi-bootloader raspberrypi-kernel, but after reboot found that the kernel did not change. rpi-update had brought me to version 6.6.25-v8+, while the --reinstall installed 6.1.21-v8+. Fiddling around with boot config has yielded no fruit. Looking for an answer before I resort to wiping and reinstalling RPi OS Bookworm.
Main issue: uname -r always gives 6.6.25-v8+ after rpi-update but I want to roll back to 6.1.21-v8+. How is this possible?
Edit: Additional info
$ ls /usr/lib/modules
6.1.0-18-arm64 6.1.0-rpi8-rpi-2712 6.6.20+rpt-rpi-2712 6.6.25-v8-16k+
6.1.0-rpi7-rpi-2712 6.1.0-rpi8-rpi-v8 6.6.20+rpt-rpi-v8
6.1.0-rpi7-rpi-v8 6.1.21-v8+ 6.6.25-v8+
$ cat /boot/firmware/config.txt
For more options and information see
http://rptl.io/configtxt
Some settings may impact device functionality. See link above for details
Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
Enable audio (loads snd_bcm2835)
dtparam=audio=on
Additional overlays and parameters are documented
/boot/firmware/overlays/README
Automatically load overlays for detected cameras
camera_auto_detect=1
Automatically load overlays for detected DSI displays
display_auto_detect=1
Automatically load initramfs files, if found
auto_initramfs=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
Don't have the firmware create an initial video= setting in cmdline.txt.
Use the kernel's default instead.
disable_fw_kms_setup=1
Run in 64-bit mode
arm_64bit=1
Disable compensation for displays with overscan
disable_overscan=1
Run as fast as firmware / board allows
arm_boost=1
[cm4]
Enable host mode on the 2711 built-in XHCI USB controller.
This line should be removed if the legacy DWC2 controller is required
(e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[all]
Uncomment to overclock. Default CPU is 1500, default GPU is 500
over_voltage=6
arm_freq=2100
gpu_freq=700
