Issue
I'm trying to get CasaOS working on my Raspberry Pi 5 but I seem to be having compatibility issues with Docker. Basically when I install CasaOS on Ubuntu it works but if I try install CasaOS on Pi OS I get all kinds of errors in docker saying that it can't access gitlab etc.
Hardware:
  • Raspberry Pi 5
  • Geekworm X1001 Pcie M.2 Key-M NVMe SSD PIP PCIe Peripheral Board for Raspberry Pi 5
  • Curcial P3 Plus 512gb NVMe M.2 SSD
CasaOS on Pi OS on Pi5
Fresh install of Raspberry Pi OS Lite (64-bit)
sudo apt update
sudo apt upgrade
sudo reboot
curl -fsSL https://get.casaos.io | sudo bash
sudo reboot
sudo docker run hello-world
Ouput
Unable to find image 'hello-world:latest' locally
latest: Pulling from library/hello-world
docker: Get "https://registry-1.docker.io/v2/library/hello-world/manifests/sha256:2d4e459f4ecb5329407ae3e47cbc107a2fbace221354ca75960af4c047b3cb13": dial tcp [2600:1f18:2148:bc02:445d:9ace:d20b:c303]:443: connect: network is unreachable.
See 'docker run --help'.
Docker on PI OS
https://github.com/slowrunner/wali_pi5/ ... pt_repo.sh
#!/bin/bash
REF:https://docs.docker.com/engine/install/debian/#install-using-the-repository
Add Docker's official GPG key:
sudo apt-get update sudo apt-get install ca-certificates curl gnupg sudo install -m 0755 -d /etc/apt/keyrings curl -fsSL https://download.docker.com/linux/debian/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg sudo chmod a+r /etc/apt/keyrings/docker.gpg
Add the repository to Apt sources:
echo
"deb [arch="$(dpkg --print-architecture)" signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/debian
"$(. /etc/os-release && echo "$VERSION_CODENAME")" stable" |
sudo tee /etc/apt/sources.list.d/docker.list > /dev/null sudo apt-get update
https://github.com/slowrunner/wali_pi5/blob/main/configs/docker/2_install_docker_pkgs.sh
#!/bin/bash
sudo apt-get install -y docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin sudo docker run hello-world
Output
More info
In both examples, there are no errors when installing docker but it just fails to work correctly.
I will mention that I tried flashing the drive with Ubuntu Server from the Pi imager and installed CasaOS and it worked perfectly!
I don't like Ubuntu though for 3 reasons.
  1. The install size is bigger
  2. It constantly spits out warning messages about some Bluetooth problem
  3. I can't connect with SSH to the ethernet address. Only WLAN
I have to stress that I'm pretty new to Linux so I don't really know what I'm doing but I would really appreciate some help and some patience if I don't understand right away.
BonesJD
