I have an external 2TB WD Elemens harddisk recently purchased plugged into the USB of my Raspberry Pi with Xbian 1.0 beta 2 installed. This disk has internal power management so it enters stand-by mode after approx 30 minutes of not being read or written. So, although the disk does stop (spin down) after a while when no one uses the Pi, it spins up again after 10-15 minutes without any external intervention.
Why could this happen, what could be accessing it? I did the following things trying to prevent daemons from read/writing it and figure out what's causing it:
  1. Added exit 0 before any command in /etc/init.d/hdparm, ntp, rsync, anacron, smartmontools, smartd
  2. Commented everything out in /etc/init/anacron.conf, cron.conf
  3. Commented all out in /etc/cron.*/0anacron files
  4. Commented all out in /etc/crontab
  5. Added exit 0 before all commands in /etc/apm/event.d/* and /etc/apm/other.d/ifplugd
  6. Tested on Openelec - here the non-needed spin-up down does not occur, the disk stays on stand-by undefinetely if the Pi is not used
  7. I unmounted the disk and this still happens, so perhaps some kind of diagnostic request is sent to it through USB, but by which program?
  8. Mounted the disk with noatime, no success.
Any idea would be appreciated.
rav_kr
  • 456
Puiu Ioan
  • 71
Basically, the WD power management and Xbian drive management don't work together, at least on beta2. Look at this post. Disable the disk's internal power management and let Xbian run the show.
tlhIngan
  • 3,372
  • 33
