It seems quite likely from the tests that you have done that your Pico is dead. This could be caused by static while handling (though less likely if it happenend while connected to a computer), or by overloading or overheating (unlikely because you haven't said that it was doing anything very strenuous). It could also be caused by overvoltage from the USB port (5.5v is the maximum recommended). Otherwise it is likely to be component failure, which, although the chances are low on the Pico can never be zero.
Other checks that you could perform: In Thonny click bottom right to see if the Pico is present. If it is then maybe it isn't fried after all. You could also look at the Device Manager if you are on a PC, and check under Ports that its COM port is present.
You could also check voltage and current draw. There are small very inexpensive USB current and voltage meters. My Pico W draws around 30mA when idle. Before you plug another Pico into the device where the previous one stopped working, it would be prudent to check that the voltage does not exceed 5.5. My PC shows 5.08, and my Raspberry Pi 4, 5.10 volts.
