I can't find WiFi configuration that I entered during Raspbian installation. I have fresh Raspberry Pi 4 with default Raspbian x64 system installed on SD card by using Raspberry Pi Imager 1.8.4.
During installation I have entered my user, password and WiFi configuration, enabled SSH and regional options.
My Pi connects to that network, however my /etc/wpa_supplicant/wpa_supplicant.conf file contains only this:
$ sudo cat wpa_supplicant.conf
update_config=1
There is no network.
I also have no /etc/NetworkManager directory.
Questions:
  1. What is going on? Is this network configuration only for first boot?
  2. I want to use multiple networks (phone hotspot first, and home network if hotspot is not available during boot). Should I just configure it in my wpa_supplicant.conf? I'm worried that initial configuration will still exist somewhere.
Kamil
  • 402
The Fundamental Problem with your question is that it's lacking one crucial item of information: Which version of the OS are you using?
Starting in the bookworm release of raspbian, the purveyors have designated a new "NetworkManager" that replaces the familiar dhcpcd. While NetworkManager uses wpa_supplicant, the settings are stored elsewhere.
However, you should have a folder named /etc/NetworkManager; double-check that.
Assuming you find that folder, you can see what little information is available in this folder: /etc/NetworkManager/system-connections/
On my system, I have to do this to see the only file in /etc/NetworkManager/system-connections/:
sudo less /etc/NetworkManager/system-connections/Mesh01.nmconnection
As far as using multiple networks, and other configuration changes, you will need to consult man nmcli (or use the GUI apparatus if you're into that). Debian offers a WiFi wiki for NetworkManager, and one for WiFi - both are helpful, but not well-organized IMHO.
Seamus
  • 23,558
  • 83
