This is similar to this question, but for different hardware and with some things already tried. My ultimate goal is to have bluetooth on UART0 and debug on UART2.
I use RPi 4B and need to redirect U-Boot console to UART2. My current setup:
  1. I configured force_eeprom_read=0 and disable_poe_fan=1 in my config.txt as described here.
  2. For now I also have dtoverlay=disable-bt and enable_uart=1 in config.txt.
  3. I configured dtoverlay=uart2 in my config.txt
  4. I prepared (and applied in config.txt) an overlay to pick uart2 in /chosen node:
    /dts-v1/;
    /plugin/;
    /{ compatible = "brcm,bcm2711";
        fragment@0 {
                target-path = "/chosen";
                __overlay__ {
                        /* uart2 */
                        stdout-path = "serial@7e201400:115200n8";
  5. When I boot the device in this configuration, U-Boot console still points to UART0.
  6. In U-Boot prompt I check serial configuration using coninfo:
    U-Boot> coninfo
    List of available devices:
    serial@7e201000 00000007 IO
    serial   00000003 IO stdin stdout stderr
  7. I can also investigate the /chosen node of device tree:
    U-Boot> fdt addr ${fdt_addr}
    U-Boot> fdt list /chosen
    chosen {
            ranges;
            #size-cells = <0x00000001>;
            #address-cells = <0x00000001>;
            compatible = "simple_bus";
            kaslr-seed = <0xb6f21e2c 0x0dbb17ef>;
            rpi-boardrev-ext = <0x00000000>;
            bootargs = "...";
            framebuffer@3eaf5000 {
            bootloader {
    The overlay applied correctly, as I now have stdout-path set to the desired UART.
  8. Further investigating the device tree:
    U-Boot> fdt list /soc/serial@7e201400
    serial@7e201400 {
            pinctrl-0 = <0x000000a0>;
            pinctrl-names = "default";
            compatible = "arm,pl011", "arm,primecell";
            reg = <0x7e201400 0x00000200>;
            interrupts = <0x00000000 0x00000079 0x00000004>;
            clocks = <0x00000007 0x00000013 0x00000007 0x00000014>;
            clock-names = "uartclk", "apb_pclk";
            arm,primecell-periphid = <0x00241011>;
            status = "okay";
            phandle = <0x000000b2>;
    This shows that the uart2 overlay was applied correctly. However, this UART is not even shown in the coninfo list.
What do I miss here?
I found the first error: the stdout-path should be defined as full path, like this: /soc/serial@7e201400:115200n8.
However, when I fix this, the device does not boot at all. This is verified by the ACT LED not blinking and ethernet port LEDs not blinking.
When I disable my overlay that updates /chosen by commenting it out in config.txt, the device boots normally.
Adam Trhon
  • 111
Look into drivers/serial/serial_bcmx_pl011.c in U-boot source. There is function bcmx_is_serial_muxed, which checks pinctrl for pin 15 - it must be ALT0. This driver is not very general. It works for Raspberry Pi uart0 only. And the same test is in driver bcm283x_mu.c for Raspberry Pi uart1.
I tried something similar and I also observed hanging U-boot, if console is not correctly set
MatsK
  • 2,882
  • 22
