I plan to use CM4 with a Wi-Fi/Bluetooth antenna. The antenna will be detachable from housing of the designed product. What sort of a cap should I use? Options are shorting and non-shorting.
Edit: CM4 has a U.FL connector, official CM4 antenna kit comes in two parts (look it up here). There is a panel mount SMA connector. Question is simple: should a shorting or a non-shorting SMA cap be used during transport of the device?
Shorting cap looks like that Non-shorting has no pin in the middle.
I did look at the docs for CM4, and even at the docs of the RF module, but there seems to be no info on that particular aspect of the design.
maciek
  • 141
