I am learning https://github.com/rust-embedded/rust-raspberrypi-OS-tutorials by an new ubuntu 22.04 in virtualbox
1 install some tools:gcc,make,curl...
2 follow the readme said,install docker and "Ensure your user account is in the docker group":
sudo snap install docker sudo groupadd docker sudo usermod -aG docker $USER newgrp docker
then
docker run hello-world
success
2 install rust:
curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh
but got:
info:downloading installer curl:(23) Failure writing output to destination rustup: command failed:downloader https://static.rust-lang.org/rustup/dist/x86_64-unknown-linux-gun/rustup-init /tmp/tmp.7fHoEietxL/rustup-init x86_64-unknown-linux-gnu
I don't know why,so I install cargo:
sudo snap install rustup
3 then,in the code floder "rust-raspberrypi-OS-tutorials-master":
cargo install cargo-binutils rustfilt
finaly got:
Successfully installed cargo-binutils,rustfilt!
4 in floder 01_wait_forever,run
make qemu
got error:
Compiling kernel ELF - rpi3 Compiling mingo v0.1.0 (/home/wk/rust-raspberrypi-OS-tutorials-master/01_wait_forever) Finished release [optimized] target(s) in 7.81sGenerating stripped binary make: rust-objcopy:no file or floder make:*** [Makefile:130:kernel8.img] error 127
I tried many times,but still can't make.Can you teach me?Thanks!
