There has been lots of documentation on the Pi5 and some discussion but it appears that the existing GPIO libraries will not work on Pi5.
Joan posted "pigpio does not work on the Pi 5, I do not think it can be made to work (but hope to be proved wrong). lgpio will work."
6by9 posted "libgpio is the correct answer for any variant of Pi now. There should be no need to directly bash registers through gpiomem holes at all".
lgpio accesses GPIO through the gpiochip device and libgpiod provides some command line tools. When I first tested these (a few years ago) the access was very restrictive but I believe this may have been somewhat relaxed.
gpiozero now uses the lgpio library by default.
raspi-gpio fails on Pi5 but pinctrl works. I have written a version of my gpioreadall which uses pinctrl.
I already use kernel drivers for SPI & i2c which are quite functional.
I have successfully tested my pi-gpio & pi_gpio libraries on Bookworm.
The main thing that is missing is hardware PWM. There has been a pwm dtoverlay (since at least Stretch) but is largely undocumented and the dtoverlay description states "4) Currently the clock must have been enabled and configured by other means" which is less than helpful. I have since found https://docs.kernel.org/driver-api/pwm.html#using-pwms-with-the-sysfs-interface; I had thought this was deprecated (like the GPIO sysfs interface) but have been assured by a Raspberry Pi Engineer that it is supported. I have written and tested c code (on Pi4 Bookworm) and am writing Python code.
The Raspberry Pi Model 5 was introduced at the end of 2023. It only works with Raspberry Pi Bookworm OS or later
However, the biggest impact for most developers is that the RPi.GPIO input/output library does not work on the Raspberry Pi model 5. This is because the RPi Model 5 now has a seperate chip caled RP1 for controlling the GPIO header. This means that hundreds of thousands of programs or maybe even millions of programs need to be modified to use one of the newer libraries such as gpiod or lgpio.
My own product also Raspberry Pi Internet Radio is such a program and would have meant a lot of work to convert all the GPIO routines to say GPIOD which does run on the RPi Model 5. So I decided to write a simple interface called GPIOconverter which converts RPi GPIO calls to one of the newer GPIO interfaces. GPIOD was advocated as the best way forward however I found that, at the time, GPIOD was poorly documented and I could not find any examples of how to handle interrupts. I eventually settled on using python3-lgpio for the GPIOconverter software. The architecture of the interface is shown below:
OUTPUT: User Program --> GPIO calls --> GPIOconverter --> LGPIO
INPUT: LGPIO events --> GPIOconverter --> User Program
The GPIOconverter software is currently available available on GitHub GPIO converter on GitHub
or download it from the following Web site. GPIOconverter from Bob Rathbone
In Bookworm (and latest Bullseye) the kernel device driver for GPIO has been updated so GPIO settings are persistent and it is now possible to specify pulls.
This means libgpiod behaves similarly to sysfs (and most tools accessing registers).
There is kernel documentation and a python module gpiod but it is difficult to follow (unless you are a kernel developer) and no User Documentation.
There are a few examples e.g. https://www.tomshardware.com/how-to/control-raspberry-pi-5-gpio-with-python-3
The current libgpiod is old (v1.6.3 in Bookworm and even older in Bullseye) the v2 code is significantly different but it unclear if or when this may be included in Raspberry Pi OS.
I decided to test the gpiod module and write a wrapper which uses the same functions as my pi_gpio library.
This obviously excludes I²C, SPI or Hardware PWM but I have code implementing these using kernel drivers which will be included in a final library as will Information functions.
This code has been updated and tested on a Pi5 and allows existing code to run with minimal change, but if writing new code use gpiod or lgpio (which includes additional functionality).
#! /usr/bin/env python3
p_gpio is a Python module for the RaspberryPi
Using gpiod Python Interface
This is a wrapper which uses the same functions as pi_gpio library.
OVERVIEW
GPIO setup_gpio - Set gpio as an input or an output
input_gpio - Returns the GPIO level__plibrary
output_gpio - Output to a GPIO channel
input_28 - Returns value of GPIO 0-27
output_28 - Sets value of GPIO 0-27
gpio_function - The current GPIO mode
get_pullupdn - The current GPIO pull/up down
2024-04-04
import gpiod
VERSION='0.2'
chip = gpiod.find_line('ID_SDA').owner() # find chip with ID_SDA
gpiomap = {} # This is a dictionary to avoid repeated chip.get_line(gpio) calls
GPIO
NOTE all gpio use Broadcom BCM numbers
INPUT=0 OUTPUT=1
LINE_REQ_DIR_AS_IS = 1
LINE_REQ_DIR_IN = 2
LINE_REQ_DIR_OUT = 3
LINE_REQ_EV_BOTH_EDGES = 6
LINE_REQ_EV_FALLING_EDGE = 4
LINE_REQ_EV_RISING_EDGE = 5
LINE_REQ_FLAG_ACTIVE_LOW = 4
LINE_REQ_FLAG_BIAS_DISABLE = 8
LINE_REQ_FLAG_BIAS_PULL_DOWN = 16
LINE_REQ_FLAG_BIAS_PULL_UP = 32
LINE_REQ_FLAG_OPEN_DRAIN = 1
LINE_REQ_FLAG_OPEN_SOURCE = 2
ACTIVE_HIGH = 1
ACTIVE_LOW = 2
BIAS_AS_IS = 1
BIAS_DISABLE = 2
BIAS_PULL_DOWN = 4
BIAS_PULL_UP = 3
DIRECTION_INPUT = 1
DIRECTION_OUTPUT = 2
def setup_gpio(gpio, direction, pud):
def setup_gpio(gpio, direction, pud=0): # optional pud
""" Set gpio as an input or an output direction: 0=IN, 1=OUT pud: 0=None 1=Up 2=Down """ line = chip.get_line(gpio) gpiomap[gpio] = line if direction: line.request(consumer="p_gpio", type=gpiod.LINE_REQ_DIR_OUT) else: f = gpiod.LINE_REQ_FLAG_BIAS_DISABLE if pud==1: f = gpiod.LINE_REQ_FLAG_BIAS_PULL_UP if pud==2: f = gpiod.LINE_REQ_FLAG_BIAS_PULL_DOWN line.request("p_gpio", gpiod.LINE_REQ_DIR_IN, f) print('pud= ', pud, 'bias= ', line.bias())
def input_gpio(gpio): """ Input from a GPIO channel. Returns HIGH=1=True or LOW=0=False """ return gpiomap[gpio].get_value()
def output_gpio(gpio, value): """ Output to a GPIO channel. value - 0/1 or False/True or LOW/HIGH """ gpiomap[gpio].set_value(value)
def gpio_function(gpio): """ Returns the current GPIO direction Only works if gpio in use Returns 0,1 (IN, OUT) """ if gpio in gpiomap: return gpiomap[gpio].direction() - 1 return 0
def get_pullupdn(gpio): """ Return the current GPIO pull Only works if gpio in use Returns 0:None/Unknown 1:Up 2:Down """ if gpio in gpiomap: return gpiomap[gpio].bias()-2 return 0
Dummy functions
def setup(): pass
def cleanup(): pass
#------------- import time
def main(): global chip SigOUT = 12 SigIN = 13 LOOPS = 20000 setup_gpio(SigOUT, 1, 0)
setup_gpio(SigIN, 0, 0)
setup_gpio(SigIN, 0, 1)
setup_gpio(SigIN, 0, 2)
t0 = time.time()
for i in range(LOOPS): output_gpio(SigOUT, 1) output_gpio(SigOUT, 0)
t1 = time.time()
print("gpiod Python\t{:>10.0f} toggles per second".format((1.0 * LOOPS) / (t1 - t0))) output_gpio(SigOUT, 1) print("{}".format(input_gpio(SigIN))) print('SigIN function= ', gpio_function(SigIN)) print('SigOUT function= ', gpio_function(SigOUT)) print('pud= ', get_pullupdn(SigIN)) print('pud= ', get_pullupdn(4))
if name == 'main': main()
gpiod V2 can be installed with pip in a Python venv and is much improved (but NOT backward compatible with V1).
