Yes.
You can find the information on all overlays and parameters in your local filesystem at /boot/overlays/README, or in the "official" repo on GitHub here.
Following is the syntax for the gpio-fan overlay:
Info: Configure a GPIO pin to control a cooling fan.
Load: dtoverlay=gpio-fan,<param>=<val>
Params: gpiopin GPIO used to control the fan (default 12)
temp Temperature at which the fan switches on, in
millicelcius (default 55000)
hyst Temperature delta (in millicelcius) below
temp at which the fan will drop to minrpm
(default 10000)
The parameter you've not specified - the one to control the temp at which the fan turns OFF - is hyst. The entry you need to turn the fan OFF after it drops by 15 deg C is:
dtoverlay=gpio-fan,gpiopin=3,temp=50000,hyst=15000
Note that units are in millicelsius.
