I am using this raspberry Pi
Architecture:                    armv7l
Byte Order:                      Little Endian
CPU(s):                          4
On-line CPU(s) list:             0-3
Thread(s) per core:              1
Core(s) per socket:              4
Socket(s):                       1
Vendor ID:                       ARM
Model:                           5
Model name:                      Cortex-A7
Stepping:                        r0p5
CPU max MHz:                     900.0000
CPU min MHz:                     600.0000
BogoMIPS:                        38.40
Vulnerability Itlb multihit:     Not affected
Vulnerability L1tf:              Not affected
Vulnerability Mds:               Not affected
Vulnerability Meltdown:          Not affected
Vulnerability Mmio stale data:   Not affected
Vulnerability Retbleed:          Not affected
Vulnerability Spec store bypass: Not affected
Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
Vulnerability Spectre v2:        Not affected
Vulnerability Srbds:             Not affected
Vulnerability Tsx async abort:   Not affected
Flags:                           half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
I plugged in my AC1200 USB-AC53 Nano Wi-Fi adapter and ran dmesg. The result is:
[    4.698502] usb 1-1.2: New USB device found, idVendor=0b05, idProduct=184c, bcdDevice= 2.10
[    4.698556] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.698579] usb 1-1.2: Product: 802.11ac NIC
[    4.698597] usb 1-1.2: Manufacturer: Realtek
[    4.698615] usb 1-1.2: SerialNumber: 123456
I installed firmware-realtek, firmware-linux, firmware-linux-free, and firmware-linux-nonfree then when I run ifconfig I don't see my wlan
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.31  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::fe91:c019:3887:5f22  prefixlen 64  scopeid 0x20<link>
        inet6 fd57:c6e2:9acf:479b:3970:b963:a9ca:1d4f  prefixlen 64  scopeid 0x0<global>
        ether b8:27:eb:5e:2b:19  txqueuelen 1000  (Ethernet)
        RX packets 154  bytes 32643 (31.8 KiB)
        TX packets 78  bytes 9163 (8.9 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 17 bytes 2111 (2.0 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 17 bytes 2111 (2.0 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Any suggestions to help me with making my wifi works?
Thanks Namir
I think there are some Wi-Fi adapters that don't work with Raspberry Pi, I have tried:
  1. ASUS USB-AX55 Nano adapter.
  2. ASUS AC1200 USB-AC53 Nano Wi-Fi
  3. TP-LINK Nano 2-in-1 USB WiFi Bluetooth Adapter AC600
All of the above didn't work.
I used an adapter written on it "compatible with Raspberry Pi", it is made by MCM electronics. This one worked.
MatsK
  • 2,882
  • 22
This question is two years old at this point but in fact, ASUS AC1200 USB-AC53 Nano WiFi dongle works on Raspberry Pi. We have Raspberry Pi 4B with this dongle, and the only thing you need to to is to build and install the firmware for it, which you can find below:
https://github.com/cilynx/rtl88x2bu
I think there are a few other similar Github repos hosting the firmware, but this one worked for me. Let me know if this works!
Junye Li
I can't see my wifi usb adapter with ifconfig
That's because ifconfig doesn't show all available interfaces, as per the documentation (man ifconfig):
If no arguments are given, ifconfig displays the status of the currently active interfaces.
I've emphasized "currently active", which means, more or less, that they are currently connected to a network and have an IP address associated with them. If you want to see all interfaces regardless of state, use -a
-a display all interfaces which are currently available, even if down
Based on the information in your question, you've tried to ensure the drivers are installed, and most likely the device is working. However, this does not automagically cause it to connect to some WLAN -- for that a configuration and password, etc., are required.
You can also try ifconfig wlan0 if you want just that, although that relies on the NIC being labelled that way (if there is only one wireless device and you are using RpiOS it probably will be, just beware that is not necessarily the case).
