i've got pi-cams: v1, v1 IR, v2 NoIR, v2 IMX219-D160 wide, and none of them can dynamically adjust it's auto-exposure/brightness by itself, when used as CCTV by Motion. they somewhat try but outputs are poor.
so far i have been manually adjusting brightness levels (15-65) in the motion.conf and restarting the daemon.
"not-even-workaround":
i could do a cron-job replacing motion.conf file for dusk and dawn, but times change throughout year (in places other than near Equator) and having to manually adjust cron-job on (weekly) basis would be still manual approach.
also it does not solve problem of sudden change during day, when sharp sun peeks between heavy clouds.
?a solution?:
  • somehow connecting photo/light-sensor/resistor
  • then trying to somehow read it's 0-255 int values in (near) real-time
  • based on those, via cron-job, replacing brightness value in the motion.conf accordingly and restarting daemon
i have GPIO board and Pi 3B.
has anyone solved something similar already or has any better/simpler solution, please?
and if so, how?
thank you!
[funnel your energy from spell-checking into actual solution...]
