Occasionally my headless Raspberry Pi becomes unresponsive.
I have configured the watchdog, but it doesn't always kick in.
So I have added a reset button which does a hard reset by connecting the GLOBAL_EN to GND.
Another solution would be to just cut off the power.
Is there a difference between those two solutions with respect to SD corruption?
user333869
  • 123
It will make no difference.
Cutting power will actually take a short time for capacitors to discharge vs instantaneous PMIC reset.
I would install a button and activate the shutdown overlay to see if this works.
See https://raspberrypi.stackexchange.com/a/42945/8697
Connecting GLOBAL_EN to GND is not a safe shutdown. Removing power from the RPi while it's running is also not a safe shutdown. A safe shutdown is one in which any pending writes to the SD card are completed before stopping the processor.
The simplest solution to your problem may be the "one-button ON-OFF" switch. It's described in this answer. If that doesn't do it for you, follow up here in the comments & I'll come up with something else.
Seamus
  • 23,558
  • 83
