I'm trying to replicate this (https://mustardcorner.com/desktop-weather) project but I'm trying to use the Pico w instead of the Pizero w he was using.
But the code obviously does not work on the Pico, would anyone know how I could adapt it to work on the Pico? This is the code from his website:
Weather API
import json
import requests
import datetime as datetime
token = "" lat = "" lon = ""
api_request_url_onecall = f"https://api.openweathermap.org/data/2.5/onecall?lat={lat}&lon={lon}&exclude=minutely&appid={token}&units=metric"
def get_weather_forecast():
data = requests.get(api_request_url_onecall)
readable_json = json.loads(data.content)
print(data.text)
def print_time(timestamp):
    print(datetime.datetime.fromtimestamp(timestamp).strftime('%d/%m/%Y %H:%M:%S'))
    return
# https://openweathermap.org/weather-conditions
# you can use this mapping table to tailor the weather conditions
# for example, you may consider 10% clouds to be "Clear" and 25% clouds or more to be "Cloudy"...
def weather_lookup(id):
    if id in range(800, 803):  # we consider below 50% clouds to be "Clear"...
        return "Clear"
    elif id in range(803, 805):
        return "Clouds"
    elif id in range(700, 800):
        return "Mist"
    elif id in range(600, 700):
        return "Snow"
    elif id in range(500, 600):
        return "Rain"
    elif id in range(300, 400):
        return "Rain"
    elif id in range(200, 300):
        return "Thunderstorm"
    else:
        return "Mist"
#  current time
print_time(readable_json["current"]["dt"])
print(readable_json["current"]["weather"][0]["main"])
print(readable_json["current"]["weather"][0]["id"])
current_weather = (weather_lookup(readable_json["current"]["weather"][0]["id"]))
print(current_weather)
#  3rd hour from now
print_time(readable_json["hourly"][3]["dt"])
print(readable_json["hourly"][3]["weather"][0]["main"])
print(readable_json["hourly"][3]["weather"][0]["id"])
threehr_weather = weather_lookup(readable_json["hourly"][3]["weather"][0]["id"])
print(threehr_weather)
#  6th hour from now
print_time(readable_json["hourly"][6]["dt"])
print(readable_json["hourly"][6]["weather"][0]["main"])
print(readable_json["hourly"][6]["weather"][0]["id"])
sixhr_weather = weather_lookup(readable_json["hourly"][6]["weather"][0]["id"])
print(sixhr_weather)
#  12th hour from now
print_time(readable_json["hourly"][12]["dt"])
print(readable_json["hourly"][12]["weather"][0]["main"])
print(readable_json["hourly"][12]["weather"][0]["id"])
twelvehr_weather = weather_lookup(readable_json["hourly"][12]["weather"][0]["id"])
print(twelvehr_weather)
#  tomorrow at midday
print_time(readable_json["daily"][1]["dt"])
print(readable_json["daily"][1]["weather"][0]["main"])
print(readable_json["daily"][1]["weather"][0]["id"])
tomorrow_weather = weather_lookup(readable_json["daily"][1]["weather"][0]["id"])
print(tomorrow_weather)
#  two days at midday
print_time(readable_json["daily"][2]["dt"])
print(readable_json["daily"][2]["weather"][0]["main"])
print(readable_json["daily"][2]["weather"][0]["id"])
twodays_weather = weather_lookup(readable_json["daily"][2]["weather"][0]["id"])
print(twodays_weather)
weather_list = [current_weather, threehr_weather, sixhr_weather, twelvehr_weather, tomorrow_weather, twodays_weather]
return weather_list
Main code
from weather_api import get_weather_forecast
import time import RPi.GPIO as GPIO import datetime as datetime
GPIO.cleanup()
servo_pin_1 = 18 servo_pin_2 = 23 button_pin = 17
GPIO.setmode(GPIO.BCM) GPIO.setup(servo_pin_1, GPIO.OUT) GPIO.setup(servo_pin_2, GPIO.OUT) GPIO.setup(button_pin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
servo_1 = GPIO.PWM(servo_pin_1, 50) # GPIO 17 for PWM with 50Hz servo_2 = GPIO.PWM(servo_pin_2, 50) # GPIO 17 for PWM with 50Hz
servo_1.start(2) servo_2.start(12) time.sleep(0.8)
servo_1.start(12) servo_2.start(2) time.sleep(0.8)
servo_1.start(6) servo_2.start(6) time.sleep(0.8)
servo_1.ChangeDutyCycle(0) servo_2.ChangeDutyCycle(0) time.sleep(.4)
positions = {"Clear": 11.9, "Clouds": 10.1, "Rain": 8, "Thunderstorm": 5.9, "Snow": 3.9, "Mist": 2.1,
           "Now": 12,
           "3hr": 10.2,
           "6hr": 8.5,
           "12hr": 6,
           "24hr": 4,
           "48hr": 2.5}
def move_servo(servo_1_position, servo_2_position): servo_1_new_position = positions[servo_1_position] servo_2_new_position = positions[servo_2_position]
servo_1.ChangeDutyCycle(servo_1_new_position)
servo_2.ChangeDutyCycle(servo_2_new_position)
time.sleep(0.5)
time.sleep(0.5)
def print_servo(servo, position): # used for testing only new_position = positions[position] print(f"Servo: {servo} Position: {new_position}")
class Timer: value = 0 max_value = (10 * 60) * 5
def __init__(self):
    pass
def reset(self):
    self.value = 0
def tick(self):
    refresh = False
    if self.value >= Timer.max_value:
        self.reset()
        refresh = True
    self.value += 1
    time.sleep(0.09)
    return refresh
def weather_toggle(current_weather_displayed): if current_weather_displayed >= max_weather_displayable: current_weather_displayed = 0 else: current_weather_displayed += 1 return current_weather_displayed
global last_refreshed_weather last_refreshed_weather = datetime.datetime.now() weather_list = get_weather_forecast()
def refresh_weather_data(current_weather_displayed, weather_list): global last_refreshed_weather the_time = datetime.datetime.now() print(f"last refresh: {last_refreshed_weather} - time now: {the_time}") if the_time >= last_refreshed_weather + datetime.timedelta(minutes=20): print("getting new weather from API") weather_list = get_weather_forecast() last_refreshed_weather = the_time else: print("using old data, no refresh needed") weathers = [ {"time": "Now", "weather": weather_list[0]}, {"time": "3hr", "weather": weather_list[1]}, {"time": "6hr", "weather": weather_list[2]}, {"time": "12hr", "weather": weather_list[3]}, {"time": "24hr", "weather": weather_list[4]}, {"time": "48hr", "weather": weather_list[5]} ] weather_to_display = weathers[current_weather_displayed] return weather_to_display, weather_list
def get_input(): if GPIO.input(button_pin) == GPIO.LOW: return True else: return False
def update_display(weather_to_display): print(f"{current_weather_displayed} - {weather_to_display['time']}: {weather_to_display['weather']}") print_servo(servo_1, weather_to_display["time"]) print_servo(servo_2, (weather_to_display["weather"])) move_servo((weather_to_display["time"]), (weather_to_display["weather"]))
if name == 'main':
current_weather_displayed = 0  # make weather display the current weather the first time
weather_to_display, weather_list = refresh_weather_data(current_weather_displayed, weather_list)
max_weather_displayable = 5
timer = Timer()
print("Ready")
while True:
    if get_input() is True:
        timer.reset()
        current_weather_displayed = weather_toggle(current_weather_displayed)
    refresh = timer.tick()
    #print(timer.value)
    if refresh is True:
I would much appreciate any help Thanks
LilData777
  • 311
