I'm trying to use Raspberry Pi for a voice recognition project.
I have Raspberry Pi 4 model B.
I was having issue downloading PyTorch with the error of "Could not find a version that satisfies the requirement torch." And I read in another place saying it might be mismatch of bit version. I used Raspberry Pi Imager to reformat my SD card to FAT32 and then downloaded the 32 bit version of Raspberry Pi OS.
When I check using "uname -m", it shows aarch64 When I check "python -c "import struct;print(8*struct.calcsize('P'))" it shows 32
I'm not sure why it's showing aarch64 when I selected 32bit version. I been having a lot of issue just trying to configure the system so I can download and use the OpenAI Whisper.
user155849
To elaborate a bit on Dougie's comment:
Add arm_64bit=0 to /boot/config.txt and reboot. Your RPi will come up with the 32-bit kernel.
What uname -m reports is the ISA of the kernel, not the userland (= everything else). A 64-bit kernel can run a 32-bit userland (but not vice versa). If you want to find out what the system binaries are, use file ..., eg. file $(which bash). On the 32-bit OS regardless of what kernel is running, you should get:
/bin/bash: ELF 32-bit LSB executable, ARM, EABI5 version 1
By default, if a 64-bit kernel is available on a 64-bit Pi it will be used. Note that if the issue is software compatibility, it's the userland that counts, so you should not have to use a 32-bit kernel, and (put another way), if what you want to do still does not work, using a 32-bit kernel won't change that.
