TLDR; I want to disable the USB hub on a RPi4 until boot is complete.
Hi, I am trying to solve a problem that I have not seen posted about.
I have a RPi4 with multiple RPiZs plugged into it acting as ethernet gadgets. The RPiZs connect to different interfaces (usb1:usb4) based on udev rules and interfaces set up in the /etc/dhcpcd.conf which match the set ups on the individual RPiZ.
When I plug a RPiZ into the RPi4 via USB, it powers up and connects via ethernet over usb. The RPi4 assigns the corresponding interface and IP address perfectly.
However, an issue occurs if the entire system is powered on at the same time. The ethernet over usb connection is made before the rules are established and the RPiZ is assigned to interface usb0 and given a random ip-address.
I have a simple script (see below) based on this question: How do I reset a USB device using a script?
The script resets USB hub which resets the network which fixes the interfaces and IP addresses. However, for automation reasons, it is important that connections are right on the first try.
I suspect the problem would be solved if I could disable the USB hub (either power or just data) until the boot is complete. I have seen a lot of threads about disabling USB after boot, but none about disabling before boot. I would appreciate any help I can get. Thanks.
# /etc/udev/rules.d/90-usbpi.rules
SUBSYSTEM=="net", ATTR{address}=="00:22:82:ff:ff:01", NAME="usb1"
SUBSYSTEM=="net", ATTR{address}=="00:22:82:ff:ff:02", NAME="usb2"
SUBSYSTEM=="net", ATTR{address}=="00:22:82:ff:ff:03", NAME="usb3"
SUBSYSTEM=="net", ATTR{address}=="00:22:82:ff:ff:04", NAME="usb4"
# added to /etc/dhcpcd.conf.
interface usb1
static ip_address=10.0.11.1/24
interface usb2 static ip_address=10.0.12.1/24
interface usb3 static ip_address=10.0.13.1/24
interface usb4 static ip_address=10.0.14.1/24
#!/bin/bash
ID=0525:a4a2
logger "Searching for $ID"
devPath=`lsusb | grep $ID | sed -r 's/Bus ([0-9]{3}) Device ([0-9]{3}).*/bus\/usb\/\1\/\2/g;'`
logger "Found $ID @ $devPath"
logger "Searching for sysPath"
for sysPath in /sys/bus/usb/devices/*; do
    logger "$sysPath/uevent"
    devName=`cat "$sysPath/uevent" | grep $devPath`
    #logger devName=$devName
    if [ ! -z $devName ]
    then
        break
    fi
done
then
    logger "Found $ID @ $sysPath, Resetting"
    logger "echo 0 > $sysPath/authorized"
    logger "echo 1 > $sysPath/authorized"
else
    logger "Could not find $ID"
fi
Rusty
  • 152
AFAIK it is not possible to "disable the USB hub" but this would be a kludge in any event.
Relying on automatic enumeration of attached devices is unpredictable.
You should explore predictable network interface names which is the normal solution to the problem of multiple interfaces.
Network interfaces will have names formed from a prefix en — Ethernet or wl — wlan followed by x indicating MAC and the MAC e.g. enxb827eb123456 or wlx00c140123456. The onboard WiFi of the Pi4, Pi3 and PIZeroW which is connected over sdio will continue to use the name wlan0
I am not sure if this would work with ethernet gadgets but you could give it a try.
In any event it you do want to allocate using udev rules you should avoid names which conflict with automatic enumeration names.
Another suggestion is that you avoid IP addresses (I don't care what IP my multiple machines are allocated). I give each a unique hostname and connect using hostname.local.
