I'm trying to build a driver on my Raspberry Pi zero 2W for a Mygica USB tv tuner obtained from Aliexpress (https://www.aliexpress.com/item/1883597971.html?spm=a2g0o.order_list.order_list_main.11.1e6f1802V06dze).
I have used followed this link to do the build www.mygica.com/support, and the device is model number T230A.
Embedded within the raspberry pi driver download is this guide to building the driver: https://drive.google.com/file/d/1mgphbZjBeR3ZFV6Y6hA6b6mrI1gBFpOl/view?usp=share_link
And this extract is the first steps in the guide:
Building the Kernel
Install Required Dependencies and Toolchain
sudo apt install git bc bison flex libssl-dev make libc6-dev libncurses5-dev
Install the 32-bit Toolchain for a 32-bit Kernel
sudo apt install crossbuild-essential-armhf
Build sources
For Raspberry Pi 2, 3, 3+ and Zero 2 W, and Raspberry Pi Compute Modules 3 and 3+:
cd linux
KERNEL=kernel7
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- bcm2709_defconfig
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage modules dtbs
I've tried these scripts on two systems. On my Raspberry Pi 4B running: Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
And also on my Windows 11 system using VirtualBox to run this Linux system: Description: Ubuntu 22.04.02 LTS Release: 22.04 Codename: jammy
On both systems the two sudo apt install.... steps work fine. But then the instruction is to cd linux. And no such folder exists, as far as I have searched. So I am confused as to what I am doing wrong, and hope somebody with greater knowledge may be able to steer me in the right direction, with a plea of "please nicely" :).
Kind regards to all who read this, Peter
